OMPi - Processing a large/long vector of floats
Postby censix » Thu Sep 21, 2017 7:06 pm
Hi
I have struggled with processing a large(ish) vector of single precision floats (~ 6MB) on the Epiphany, using OMPi. Since the data is way too big for the local (32kb)
memory of a single epiphany core, I need a way to efficiently pipe this vector to any number of epiphany cores (1-16) in manageable chunks. Then each core can do
a relatively simple calculation, a moving average, and write the result vector back to shared RAM. Each core should do the moving average calculation
with a different window length parameter, so that I can calculate up to 16 different of these averages simultaneously.
What I have failed to do is piping the input vector and the 16 ouput vectors efficiently back and forth between the epiphany and the host. I guess my C programming
and understanding of memory address space is a bit rusty :!
I would really appreciate if anyone here was able to give me an indication on how to do this best
Cheers
S.
censix
Re: OMPi - Processing a large/long vector of floats
Postby censix » Fri Sep 22, 2017 10:47 am
It seems that I may have been looking in the wrong place and OMPi is not the right tool for me.
Instead the epiphany BSP library seems to be what I need.
https://github.com/coduin/epiphany-bsp
I will investigate.
censix
Return to OpenMP
