Parallella Community • View topic - PEC_NORTH/SOUTH Clustering Guidance Needed
PostPosted: Thu Mar 23, 2017 8:32 pm
by eric
I have been trying to get two (then more) Parallellas communicating via PEC_NORTH/PEC_SOUTH for some time, but keep hitting roadblocks. I am using the Porcupine boards with ribbon cables. The first hurdle is changing one of the Epiphany ROW/COL to (36,8).
I have edited the platform.hdf and changed CHIP_ROW to 36.
I have a jumper on the Porcupine, pulling YID0 up to 1.8V.
After reboot, running any software that accesses the Epiphany gives me:
e_open(): ECORE[0,0] MEM mmap failure.
And then a segmentation fault.
According to this thread (https://parallella.org/forums/viewtopic.php?f=23&t=3659), this combo has worked in the past. However their code does not run on the latest SDK. Any ideas out there?
Re: PEC_NORTH/SOUTH Clustering Guidance Needed
PostPosted: Sat Mar 25, 2017 3:02 pm
by olajep
PostPosted: Mon Mar 27, 2017 2:13 pm
by eric
Thanks for the response Ola, I will follow your advice and post a follow-up.
-Eric
PostPosted: Tue Mar 28, 2017 2:46 pm
by peteasa
See viewtopic.php?f=23&t=3659. It has also been proven with ribbon cables. Mailbox should allow communication with local arm core on both epiphany chips I think. None of this is proven with the latest elink / sdk but the steps that were taken to get it to work previously should still work. Expect to have to modify kernel driver and sdk code.
Peter.
PostPosted: Fri Mar 31, 2017 7:37 pm
by olajep
