Port U-boot 2013 to 2017 version
Postby rosalva40 » Fri Mar 03, 2017 3:32 pm
Hello, i am traying to port this configuration to u-boot 2017:[url] https://rocketboards.org/foswiki/view/D ... rStratixIV
This manual use 2013 version for U-boot, and it's works fine, but when i try to use the 2017 version doesn't work. I am trying to load u-boot on ram. This error appears in console ( jtag uart) when i load it:
"initcall sequence d8000e1c failed at call d7fc053c (err=-19) ### ERROR ### Please RESET the board ###"
I think, maybe, the error is on device tree source.
Can anyone help me?.... Thanks
Sory for my bad english
Re: Port U-boot 2013 to 2017 version
Postby sebraa » Fri Mar 03, 2017 9:01 pm
This forum is about the Parallella board, which contains a Xilinx Zynq FPGA (no Altera Stratix IV), which in turn uses a dual-core ARM hardcore (no single-core NIOS2 softcore). If you just registered to get help for your problem here, you chose the wrong platform. There might be a chance that someone can help, but I wouldn't hold my breath.
You don't go to a winery for help baking bread either.
