md5sum parabuntu img
Postby beco » Thu Apr 13, 2017 4:21 am
Dear parausers,
I am having trouble booting my microserver board with the image.
It never gets an IP address. As I don't have HDMI monitor/cable/connector, nor RS232, I am flying blind.
First thing, then, can anyone confirm if my download is ok?
Is this the MD5SUM of the following image?
$ md5sum parabuntu-2016.11.1-headless-z7010.img
4b8d896a49e71de7a1cd312b5cd2bead parabuntu-2016.11.1-headless-z7010.img
I can't find the info on the net. Note that I calculate it after unziping, because I already had deleted the ziped file.
Thank you. I hope we find soon what is the cause.
Beco.
PS. I saw some troubleshootings, but they ask to boot it with HDMI to change IP to static. I can't do that.
Also, for some reason, I cannot mount the 32GB sd card I copyed with "dd". It gives me the following error:
$ mount /dev/sdb1 /media/usb0
mount: wrong fs type, bad option, bad superblock on /dev/sdb1,
missing codepage or helper program, or other error
In some cases useful info is found in syslog - try
dmesg | tail or so.
And dmesg (syslog the same) just give this message:
[20597.417471] FAT-fs (sdb1): utf8 is not a recommended IO charset for FAT filesystems, filesystem will be case sensitive
beco
Re: md5sum parabuntu img
Postby beco » Thu Apr 13, 2017 4:46 am
I've found sha256sum in the github repo:
$ cat sha256sum.txt
98157535a9c851ff238f64d84207036f4ccf9e437d0a3eb7d9d0e0cf91c24a82 parabuntu-2016.11.1-hdmi-z7010.img.gz
dac43991996e1d6319a947d1812d0fbcb4c438e0fb1d8c6a00d25b2427d6123c parabuntu-2016.11.1-hdmi-z7020.img.gz
ac314a4fb9ab04ccef46e76727aadfab8b6045b188c975ba13f8657a6151b6c7 parabuntu-2016.11.1-headless-noelink-z7010.img.gz
2d20f3badce1478741bb08009867a1e4bf801e03152de820b27206fedd937cd5 parabuntu-2016.11.1-headless-noelink-z7020.img.gz
3d88e8c979b09d1bb31dd6628a66be4e6ddc840a6d35131689e6c3f576f9fd08 parabuntu-2016.11.1-headless-z7010.img.gz
2f3b5efbaad7e20cf87227ef3df73f23fd15d05438337d9e4ff30aeb007d910a parabuntu-2016.11.1-headless-z7020.img.gz
beco
Postby sebraa » Tue Apr 18, 2017 4:37 pm
beco wrote:[20597.417471] FAT-fs (sdb1): utf8 is not a recommended IO charset for FAT filesystems, filesystem will be case sensitive
This is a warning, not an error. The FAT file system (containing the boot files) should be mounted correctly and be accessible. Also, note that the second partition (sdb2) should contain the actual root file system, using ext4. You must be able to mount both systems correctly, otherwise your card won't work.
Did you write the image to /dev/sdb (which is correct) or to /dev/sdb1 (which is wrong)?
Best Regards,
Postby olajep » Tue Apr 18, 2017 5:15 pm
beco wrote:$ mount /dev/sdb1 /media/usb0
That looks a bit suspicious. Usually it's /dev/mmcblkX but I guess a USB <-> sdcard apdapter could show up as /dev/sdX.
Are you sure you're writing to a block device and not to a partition? It should be /dev/sdX, not /dev/sdXN (e.g. /dev/sdd, not /dev/sdd1)
Try this:
$ dmesg -w
<PLUG IN SD CARD or USB adapter>
[4504510.617941] mmcX: new high speed SDHC card at address e624
[4504510.618995] mmcblkX: mmc0:e624 SD08G 7.40 GiB
[4504510.636063]  mmcblkX: p1
<Ctrl-C>
$ su
Password: <ENTER PASSWORD>
$ gunzip -c parabuntu-2016.11.1-hdmi-X.img.gz | dd of=/dev/mmcblkX bs=1M
$ sync
The sync command is important. It forces the OS to flush the disk buffer cache to the sdcard.
What's the model of your sdcard?
What's the model of your usb adapter?
// Ola
