[solved] Parallella Not Booting -- SD Issue?
Postby micahasmith » Fri May 12, 2017 8:27 pm
Hi all--
Well it only took me 3/4 years to try out my kickstarter parallella, which i just did, and... its not booting.
I tried to burn the SD card using my mac, but i feel like its not working. Note that the below says that the disk has a format of type FAT32-- wouldnt this image be ext or something?
dev diskutil info disk2
   Device Identifier:        disk2
   Device Node:              /dev/disk2
   Whole:                    Yes
   Part of Whole:            disk2
   Device / Media Name:      SD Card Reader
   Volume Name:              Not applicable (no file system)
   Mounted:                  Not applicable (no file system)
   File System:              None
   Content (IOContent):      FDisk_partition_scheme
   OS Can Be Installed:      No
   Media Type:               Generic
   Protocol:                 USB
   SMART Status:             Not Supported
   Disk Size:                31.9 GB (31914983424 Bytes) (exactly 62333952 512-Byte-Units)
   Device Block Size:        512 Bytes
   Read-Only Media:          No
   Read-Only Volume:         Not applicable (no file system)
   Device Location:          Internal
   Removable Media:          Removable
   Media Removal:            Software-Activated
   Virtual:                  No
   OS 9 Drivers:             No
   Low Level Format:         Not supported
 dev diskutil info disk2s1
   Device Identifier:        disk2s1
   Device Node:              /dev/disk2s1
   Whole:                    No
   Volume Name:              NO NAME
   Mounted:                  Yes
   Mount Point:              /Volumes/NO NAME
   Partition Type:           Windows_FAT_32
   File System Personality:  MS-DOS FAT32
   Type (Bundle):            msdos
   Name (User Visible):      MS-DOS (FAT32)
   Media Type:               Generic
   Protocol:                 USB
   Volume UUID:              CE9B8E7C-C658-36BA-BF55-5D8797D9E226
   Disk Size:                31.9 GB (31910789120 Bytes) (exactly 62325760 512-Byte-Units)
   Volume Total Space:       31.9 GB (31902400512 Bytes) (exactly 62309376 512-Byte-Units)
   Volume Used Space:        3.0 MB (3047424 Bytes) (exactly 5952 512-Byte-Units) (0.0%)
   Volume Available Space:   31.9 GB (31899353088 Bytes) (exactly 62303424 512-Byte-Units) (100.0%)
   Allocation Block Size:    32768 Bytes
   Read-Only Media:          No
Any tips for troubleshooting on a mac?
micahasmith
Re: Parallella Not Booting -- SD Issue?
Postby micahasmith » Sat May 13, 2017 12:45 pm
Ok. I got past the first issue i think. The documentation for mac is a bit off-- it doesnt specify that you need to put /dev infront of the disk.
I did `sudo dd if=~/Downloads/ubuntu-15.04-esdk-2016.3-headless-z7020.img of=/dev/disk2 bs=1m` and it worked.
NOW an new issue!
I boot up, and the CR10 light comes on steady, but the CR8 light blinks-- any ideas?
micahasmith
Postby olajep » Sat May 13, 2017 12:59 pm
Fixed in the 2016.11 release
Download parabuntu-2016.11.1-headless-z7020.img.gz from here:
https://www.parallella.org/create-sdcard/
micahasmith wrote:Well it only took me 3/4 years to try out my kickstarter parallella, which i just did, and... its not booting.
Better late than never :)
// Ola
Postby micahasmith » Sat May 13, 2017 2:08 pm
I'm in!!
Thanks for taking the time to help Ola. Much appreciation. :D
micahasmith
