u30
u30
Postby Salloy » Fri Jun 16, 2017 8:23 pm
How hot should the chip at u30 be getting. I'm setting up my board and the chip at u30 seams to be getting really really hot. also none of the LEDs are lighting up anymore after i found that it was getting hot. anyone have any ideas?
Salloy
Re: u30
Postby olajep » Tue Jun 20, 2017 3:28 pm
Salloy wrote:How hot should the chip at u30 be getting. I'm setting up my board and the chip at u30 seams to be getting really really hot. also none of the LEDs are lighting up anymore after i found that it was getting hot. anyone have any ideas?
Ugh! sounds like the wrong power supply or a short somewhere on the board or a faulty component to me.
Before I let you RMA please double-check that you did follow the instructions here:
https://www.parallella.org/quick-start/
Most importantly:
- A high quality 2000mA rated 5V DC power supply with 5.5mm OD / 2.1mm ID center positive polarity plug.
- heatsink
- fan
The U30 (ISL9305) provides power rails for the Epiphany, DDR, and some of the I/O banks on the Zynq.
Its power-good signal is connected to green led cr8.
Schematics if you're interested:
https://github.com/parallella/parallell ... ematic.pdf
// Ola
Re: u30
Postby Salloy » Wed Jun 21, 2017 5:35 pm
When I got this Board I look up major problems and saw that the Power supply was one of the biggest problems. This being said I made sure that I only used the power supply provided with the board. I then went to the website to make sure that I got the correct OS and correctly install the included heatsink.I properly applied the heatsink and used a large house fan to help with the cooling. after finding that the board was having problems I looked up the schematics myself to investigate what was going on. and what I think is happening is the chip is getting power and as you said shorting out.
Salloy
Re: u30
Postby olajep » Wed Jun 21, 2017 6:05 pm
Sorry about that. It does look like you may have a defective board. Please return (RMA) it to the place of purchase so that we can have it looked at. We can then ship you a new board or offer a refund.
// Ola
Re: u30
Postby Salloy » Wed Jun 21, 2017 7:01 pm
There is the problem. The window to submit a return to Amazon closed a few days ago. so I'm not sure what to do now. I will contact Amazon and see if there is any way I can get this returned.
Salloy
Re: u30
Postby Salloy » Mon Aug 07, 2017 3:04 pm
Well, that was a bust. Is there anywhere I can order the chip and replace it my self. Amazon is keeping their hands off of this. I'll try to fix it my self. I have ordered and received another one.
Salloy
Re: u30
Postby olajep » Wed Aug 09, 2017 3:13 pm
Salloy wrote:Well, that was a bust. Is there anywhere I can order the chip and replace it my self. Amazon is keeping their hands off of this.
Looked around and unfortunately neither digikey nor mouser seem to have a compatible part in stock AFAICT. And minimum order quantity is 6000... :(
And even if you did manage to replace the component there's no guarantee that no other components were fried as well. Depends on how the U30 failed
Full part name: ISL9305IRTHWBNLZ-T
Re: u30
Postby Salloy » Wed Aug 09, 2017 10:04 pm
Well at this point what do i have to loose. Ill look at what i can find. I really would like to get 2 of them up and running. really not happy just calling it quits just yet. ;-)
Salloy
