Page 2 of 3
Re: Troubleshooting the Parallella at Startup
Posted:
Fri May 09, 2014 1:06 am
by heymanj
Posted:
Fri May 09, 2014 5:13 am
by shodruk
Try these commands and post the output.
ls /sys/class/drm/
cat /sys/class/drm/card0-HDMI-A-1/modes
Posted:
Fri May 09, 2014 10:39 am
by heymanj
Posted:
Fri May 09, 2014 12:21 pm
by shodruk
Posted:
Sat May 10, 2014 12:22 am
by heymanj
Posted:
Sat May 10, 2014 12:25 am
by heymanj
Posted:
Fri May 16, 2014 2:18 pm
by MarkjBOINC
I've recently received my 2 boards and can't get them to boot.
Power supply is a Belkin rated for 2.1A so should be suitable. I have also tried reimaging the microSD card (I tried 3, all SanDisk). When I try and power it up I get a single green LED on and then it blinks about once a second. I don't get the network LED's and router doesn't show any new devices on the network. Both boards seems to do the same.
I have tried plugging in an HDMI and get no signal on it, so I don't think its got far enough in the boot process to display anything. I don't have a serial cable so haven't tried it.
Posted:
Mon May 19, 2014 12:25 pm
by MarkjBOINC
I tried a genuine Apple10w power supply and that wouldn't do it either. I bought a rather expensive 5v power supply rated to 3A this time. That fixed the blinking LED issue.
Couldn't boot off the 1st of the micro-SD cards. I got a couple of penguins on the top of the screen and it stopped at that point (on a screen plugged into HDMI). A 2nd micro-SD has booted up, although all 3 had the same image written.
I have put a 60mm fan on the top of the case. It runs off a standard USB power pack so that should keep it nice and cool.
Posted:
Thu Jul 31, 2014 11:41 pm
by cepope13
I can't get hdmi either. The unit boots fine and I can ssh to edit the devicetree per the instructions. However I get:
linaro-nano:/mnt> sudo dtc -I dts devicetree.dts -O dtb -o devicetreeb.dtb
Error: devicetree.dts:1.2-3 syntax error
FATAL ERROR: Unable to parse input tree
I tried reverse compiling the existing dtb and I didn't see anything related to bootargs?
What should the exact contents of devicetree.dts be?
Posted:
Fri Aug 01, 2014 9:12 am
by 9600
The device tree source can be found on GitHub:
https://github.com/parallella/parallell ... llella.dtsCheers,
