Parallella Community • View topic - Dwarf Fortress??
Dwarf Fortress??
Dwarf Fortress??
Postby chubbylamma » Sat Dec 12, 2015 3:08 am
Hey guys,
I was looking into Razberry Pie and then i found this board. I've always wanted to have a system that i could take with me, and could run on a battery. Emulators would be the main thing running on it but i got to thinking about other games, and seeing as how this can run Linux...
Can it run dwarf fortress? It is entirely CPU based with pre-SNES graphics and i don't have 100 dollar's to spend on a Parallella. Thanks for the response.
chubbylamma
Re: Dwarf Fortress??
Postby dobkeratops » Sat Dec 12, 2015 3:40 pm
RPi is probably a better bet for games as it has a GPU. This is best thought of for parallel programming research and embedded use IMO
i wonder if you could use parallelism for an emulator :) some cores emulating each hardware unit of the original machine..
EDIT: actually the Zynq FPGA should have great use for emulators
dobkeratops
Postby piotr5 » Sun Dec 13, 2015 10:48 am
don't know if it's better than raspberry pi, but there's also odroid xu4
ARM Cortex-A15/A7 (Samsung Exynos 5422), 4x 2.0GHz + 4x 1.3GHz • GPU: Mali-T628MP6 (600MHz) • RAM: 2GB LPDDR3 (933MHz)
piotr5
Postby dobkeratops » Mon Dec 14, 2015 3:32 pm
dobkeratops
Postby 8l » Mon Dec 14, 2015 8:39 pm
FYI, pine a64 is cheap and new raspberry pi alternative:
https://www.kickstarter.com/projects/pi ... per-comput
8l
