Parallella Community • View topic - Eigenvalue decomposition using parallel computing -epiphany
Postby rajat_1397 » Mon May 22, 2017 7:01 am
I would like some help with eigenvalue decomposition of a random matrix whose computation runs parallelly on 16 cores of the epiphany chip including the data transfers between the cores. I have already written a matlab code over a single core which includes few sub functions which have to be distributed over the 16 cores to be run parallelly keeping in mind the data transfer between the cores. I haven't used the eig() function since it takes more time to compute.
rajat_1397
Re: Eigenvalue decomposition using parallel computing -epiph
Postby sebraa » Mon May 22, 2017 1:27 pm
...what do you want to say?
Postby rajat_1397 » Tue May 23, 2017 5:06 am
I would like the zync processor to distribute the work among the 16 epiphany processors in computing the eigenvalue of a matrix
rajat_1397
Postby sebraa » Tue May 23, 2017 7:25 am
Then just do it. We won't do your homework, so if you don't ask specific questions, you won't get any answers.
Postby nickoppen » Tue May 23, 2017 10:40 am
One of the standard examples that is probably already on your parallella is matrix multiplication. How about you start there.
nickoppen
Postby rajat_1397 » Fri May 26, 2017 4:19 am
Can you give me a sample code so I can understand as to how to access epiphany cores for computing. Thanks in advance!
rajat_1397
Postby nickoppen » Fri May 26, 2017 11:10 am
It's all here:
Also, have a look on your parallella for a folder called /home/parallella/parallella-examples. Same stuff, just local.
nickoppen
