Parallella Community • View topic - Example: In-line maths calculation, in internal memory
Moderator: Dr.BeauWebber
Postby Dr.BeauWebber » Thu Jun 20, 2013 9:26 am
Dr.BeauWebber
Re: Example: In-line maths calculation, in internal memory
Postby Dr.BeauWebber » Thu Jun 20, 2013 4:22 pm
skeleton_v4.tar.gz
example maths test - tar file
(221.09 KiB) Downloaded 2924 times
Reason: Added more information about testing the code.
Dr.BeauWebber
Postby shodruk » Sun Jun 23, 2013 8:31 am
Postby Hoernchen » Sun Jun 23, 2013 12:16 pm
Hoernchen
Postby Dr.BeauWebber » Mon Jun 24, 2013 12:52 pm
Reason: add information (e-run timing)
Dr.BeauWebber
Postby aolofsson » Mon Jun 24, 2013 3:14 pm
More often than not, when things run really slow, it's because code is being fetched out of external. Any PC address above 0x000xxxxx is going to slow things down by >100X.
Can you try this just to make sure all the critical code is running out of local?
1.) e-ojdump -D "your_epiphany.elf" > dump (tar and attach)
2.) e-run --trace "your_epiphany.elf" > trace (tar and attach)
Postby Dr.BeauWebber » Mon Jun 24, 2013 7:40 pm
Ah, thanks.
Ben has asked to reclaim access to their hardware, but I assume I can do this test on other hosts :
Can I just do the objdump and trace from a simple a.out file, as opposed to creating the actual Epiphany .elf files ?
I certainly get assembly code when I try.
If not, I am building a test Arm installation on a Raspberry Pi, to help validate the latest changes to the aplc compiler, and I could recreate the Epiphany code there.
Dr.BeauWebber
Postby ysapir » Mon Jun 24, 2013 8:55 pm
a.out is just the default name for the executable generated by the gnu compilers, if you don't specify an explicit name.
In your question, do you mean if you could analyze the executable generated by ARM/x86 compiler instead of Epiphany compiler? If so, the answer is obviously no, since the binaries are different between platforms and there is limited amount of info that you can learn from that. However, you don't really need the actual hardware to do your test. You can work with the cross-build tools on your PC (esdk.4.13.04.24). e-objdump will work on the executable generated by e-gcc on any platform. e-run is a simulator, thus no need for the hardware.
ysapir
Postby Dr.BeauWebber » Mon Jun 24, 2013 10:07 pm
trace.tar.gz
compressed trace file
(330.96 KiB) Downloaded 2889 times
dump.tar.gz
compressed dump file
(2.47 MiB) Downloaded 2952 times
Dr.BeauWebber
Postby ysapir » Tue Jun 25, 2013 7:09 am
A quick look at your objdump listing shows that all of your code is being run from external memory. Also note that for the specific code you attached, no LDF was used in compilation, so all addresses are resolved using the default linker LDF, where ext. mem is at 0x80000000. I am surprised if you manage to run this executable on a real hardware.
ysapir
Return to APL
Users browsing this forum: No registered users and 38 guests
