Parallella Community • View topic - Power Cables
Power Cables
Power Cables
Postby AlphaCluster » Thu Jan 23, 2014 1:06 am
So can anyone confirm if this power supply would be safe to use?
http://www.digikey.com/product-detail/e ... ND/3094912
Based on the Voltage, Amperage and the plug it looks like it should work. Is this true or am I better off getting the accessory kit?
AlphaCluster
Re: Power Cables
Postby ubii » Thu Jan 23, 2014 1:13 am
AlphaCluster,
The voltage and amperage are correct, but the polarization needs to be positive center, not negative.
ubii
Re: Power Cables
Postby AlphaCluster » Thu Jan 23, 2014 1:24 am
Ok well how about attempt number 2?
http://www.digikey.com/product-detail/e ... ND/2506963
Will this one work or will the connector be too short? This one is only 9.5mm the other was 11mm I noticed.
AlphaCluster
Re: Power Cables
Postby ubii » Thu Jan 23, 2014 1:36 am
AlphaCluster,
That adapter should work, but here is a link to the actual adapter that was included in my accessory bundle. Not only is it cheaper, but it is rated for 3A. You may even be able to find it cheaper, if you google the manufacturer and manufactuer number listed, in the link below.
http://www.jameco.com/webapp/wcs/stores ... 2082222_-1
ubii
Re: Power Cables
Postby AlphaCluster » Thu Jan 23, 2014 1:59 am
Would three amp be better? I was only looking at 2amp adapters cause that was called out in the quick start guide.
AlphaCluster
Re: Power Cables
Postby 9600 » Thu Jan 23, 2014 9:00 am
3 amp would just give you more budget for peripheral and daughter card expansion.
Re: Power Cables
Postby TrikingSheep » Thu Jan 23, 2014 9:49 am
I tis always beneficial to use a PSU that has greater capacity than needed.
It helps with future expansion as Andrew hinted at, and also doesn't stress the PSU.
Kind Regards,
Julian.
TrikingSheep
Re: Power Cables
Postby gceline » Fri Jan 24, 2014 2:02 am
Currently we are shipping most of accessory kits with the supplies mentioned above. Clusters will ship with this supply
http://www.digikey.com/product-search/e ... maction=on
which is 2.5A.
Anything below 2A is dangerous, but higher rating will not do any harm
Graham
Adapteva
gceline
Re: Power Cables
Postby nmalinoski » Fri Apr 25, 2014 2:31 am
I got one of these when I bought a BeagleBone Black from Adafruit; it appears to fit and power my Parallellas just fine: https://www.adafruit.com/products/276
nmalinoski
Re: Power Cables
Postby Gravis » Fri Apr 25, 2014 2:50 pm
you can get .
Gravis
