Verified Peripherals (Tested Hardware Accessories)
Re: Verified Peripherals (Tested Hardware Accessories)
Postby nutpoasa » Sat Jul 05, 2014 5:54 am
You can add
Logitech tk820 wireless keyboard with touchpad
and if you do not wish to use one of your USB ports for wireless
Netgear Universal WiFi Adapter WNCE2001
nutpoasa
Postby adexmont » Thu Jul 31, 2014 8:32 am
microsift mouse 5V 100mA model 1113
keyboard hama sl 640 5V 50mA
delock 87461 passive usb hub 4>1
this peripherals are working for my board
(i'm not able to get hdmi video output so i can't test deep but as led light up i suppose that everything is working)
thanks
Postby xilman » Mon Aug 18, 2014 4:32 pm
Not sure whether this is a "peripheral" or not but it certainly lies on the periphery of my boards. In fact, it is the periphery.
Andrew Back sells a cluster case, fan and PSU to house up to 4 Parallella systems. Details at http://groundelectronics.com/products/p ... luster-kit
A picture of my cluster is below. Yes, it is using an elderly 100MB ethernet hub pro tem but a decent low-latency 8-port Gbe switch should arrive in a day or two. When it comes the cable management will be a little more professional than a random selection of cable ties.
Incidentally, the monitor shows my "redless-display" issue described in another thread.
2014-08-18 16.27.42.png (933.77 KiB) Viewed 34047 times
xilman
Postby stingraze » Tue Mar 17, 2015 9:47 am
Some peripherals working on the Parallella.
ELECOM TK-U77MPSV Japanese keyboard
ELECOM U2H-TAP1420BWH USB HUB
ELECOM M-LS2URBK laser mouse
LG FLATRON IPS226V-PN HDMI enabled Monitor
stingraze
