Link errors when using clang and libc++
Postby alexB » Sun May 24, 2015 7:35 pm
Has anyone used the libc++1 etc. in the image successfully?
I foolishly spent the time to build a libc++ boost without verifying that hello work will link...
alexB
Re: Link errors when using clang and libc++
Postby alexB » Mon May 25, 2015 9:12 am
$ cat test.cpp
#include <iostream>
int main() {
std::cout << "Hello world\n";
return 0;
$ clang -v -std=c++11 -stdlib=libc++ -lc++ test.cpp
Ubuntu clang version 3.6.0-2ubuntu1~trusty1 (tags/RELEASE_360/final) (based on LLVM 3.6.0)
Target: arm-unknown-linux-gnueabihf
Thread model: posix
Found candidate GCC installation: /usr/lib/gcc/arm-linux-gnueabihf/4.8
Found candidate GCC installation: /usr/lib/gcc/arm-linux-gnueabihf/4.8.2
Found candidate GCC installation: /usr/lib/gcc/arm-linux-gnueabihf/4.9
Found candidate GCC installation: /usr/lib/gcc/arm-linux-gnueabihf/4.9.1
Selected GCC installation: /usr/lib/gcc/arm-linux-gnueabihf/4.8
Candidate multilib: .;@m32
Selected multilib: .;@m32
"/usr/lib/llvm-3.6/bin/clang" -cc1 -triple armv6-unknown-linux-gnueabihf -emit-obj -mrelax-all -disable-free -disable-llvm-verifier -main-file-name test.cpp -mrelocation-model static -mthread-model posix -mdisable-fp-elim -fmath-errno -masm-verbose -mconstructor-aliases -fuse-init-array -target-cpu arm1136jf-s -target-abi aapcs-linux -mfloat-abi hard -target-linker-version 2.24 -v -dwarf-column-info -resource-dir /usr/lib/llvm-3.6/bin/../lib/clang/3.6.0 -internal-isystem /usr/include/c++/v1 -internal-isystem /usr/local/include -internal-isystem /usr/lib/llvm-3.6/bin/../lib/clang/3.6.0/include -internal-externc-isystem /usr/lib/gcc/arm-linux-gnueabihf/4.8/include -internal-externc-isystem /usr/include/arm-linux-gnueabihf -internal-externc-isystem /include -internal-externc-isystem /usr/include -std=c++11 -fdeprecated-macro -fdebug-compilation-dir /home/alex/clang-test -ferror-limit 19 -fmessage-length 80 -mstackrealign -fno-signed-char -fobjc-runtime=gcc -fcxx-exceptions -fexceptions -fdiagnostics-show-option -fcolor-diagnostics -o /tmp/test-eb1bf4.o -x c++ test.cpp
clang -cc1 version 3.6.0 based upon LLVM 3.6.0 default target arm-unknown-linux-gnueabihf
ignoring nonexistent directory "/include"
#include "..." search starts here:
#include <...> search starts here:
/usr/include/c++/v1
/usr/local/include
/usr/include
End of search list.
"/usr/bin/ld" -z relro -X --hash-style=gnu --build-id --eh-frame-hdr -m armelf_linux_eabi -dynamic-linker /lib/ld-linux-armhf.so.3 -o a.out /usr/lib/gcc/arm-linux-gnueabihf/4.8/../../../arm-linux-gnueabihf/crt1.o /usr/lib/gcc/arm-linux-gnueabihf/4.8/../../../arm-linux-gnueabihf/crti.o /usr/lib/gcc/arm-linux-gnueabihf/4.8/crtbegin.o -L/usr/lib/gcc/arm-linux-gnueabihf/4.8 -L/usr/lib/gcc/arm-linux-gnueabihf/4.8/../../../arm-linux-gnueabihf -L/usr/lib/gcc/arm-linux-gnueabihf/4.8/../../../../lib -L/usr/lib/llvm-3.6/bin/../lib -L/lib/arm-linux-gnueabihf -L/lib/../lib -L/usr/lib/arm-linux-gnueabihf -L/usr/lib/../lib -L/usr/lib/arm-linux-gnueabihf/../../lib -L/usr/lib/gcc/arm-linux-gnueabihf/4.8/../../.. -L/usr/lib/llvm-3.6/bin/../lib -L/lib -L/usr/lib -lc++ /tmp/test-eb1bf4.o -lgcc --as-needed -lgcc_s --no-as-needed -lc -lgcc --as-needed -lgcc_s --no-as-needed /usr/lib/gcc/arm-linux-gnueabihf/4.8/crtend.o /usr/lib/gcc/arm-linux-gnueabihf/4.8/../../../arm-linux-gnueabihf/crtn.o
/tmp/test-eb1bf4.o:(.ARM.extab.text._ZNSt3__124__put_character_sequenceIcNS_11char_traitsIcEEEERNS_13basic_ostreamIT_T0_EES7_PKS4_j[_ZNSt3__124__put_character_sequenceIcNS_11char_traitsIcEEEERNS_13basic_ostreamIT_T0_EES7_PKS4_j]+0x0): undefined reference to `__gxx_personality_v0'
/tmp/test-eb1bf4.o:(.ARM.extab.text._ZNSt3__116__pad_and_outputIcNS_11char_traitsIcEEEENS_19ostreambuf_iteratorIT_T0_EES6_PKS4_S8_S8_RNS_8ios_baseES4_[_ZNSt3__116__pad_and_outputIcNS_11char_traitsIcEEEENS_19ostreambuf_iteratorIT_T0_EES6_PKS4_S8_S8_RNS_8ios_baseES4_]+0x0): undefined reference to `__gxx_personality_v0'
/tmp/test-eb1bf4.o:(.ARM.extab.text._ZNSt3__113basic_ostreamIcNS_11char_traitsIcEEE6sentryD2Ev[_ZNSt3__113basic_ostreamIcNS_11char_traitsIcEEE6sentryD2Ev]+0x0): undefined reference to `__gxx_personality_v0'
/tmp/test-eb1bf4.o:(.ARM.extab.text._ZNKSt3__121__basic_string_commonILb1EE20__throw_length_errorEv[_ZNKSt3__121__basic_string_commonILb1EE20__throw_length_errorEv]+0x0): undefined reference to `__gxx_personality_v0'
/tmp/test-eb1bf4.o:(.ARM.extab.text._ZNSt3__113basic_ostreamIcNS_11char_traitsIcEEE5flushEv[_ZNSt3__113basic_ostreamIcNS_11char_traitsIcEEE5flushEv]+0x0): undefined reference to `__gxx_personality_v0'
/usr/lib/gcc/arm-linux-gnueabihf/4.8/../../../arm-linux-gnueabihf/libc++.so: undefined reference to `_Unwind_SjLj_RaiseException'
/usr/lib/gcc/arm-linux-gnueabihf/4.8/../../../arm-linux-gnueabihf/libc++.so: undefined reference to `_Unwind_SetIP'
/usr/lib/gcc/arm-linux-gnueabihf/4.8/../../../arm-linux-gnueabihf/libc++.so: undefined reference to `_Unwind_SetGR'
/usr/lib/gcc/arm-linux-gnueabihf/4.8/../../../arm-linux-gnueabihf/libc++.so: undefined reference to `_Unwind_GetIP'
alexB
