Parallella SDK
Posted: Mon Feb 16, 2015 4:43 pm
Hello every one
First of all , i wanna let you know that i'm new with all this stuff
I'm trying to master the Parallella with all of its options, so i decide to start with programming the ARM and then to program both ARM and epiphany at the same time and after that i will bring some co-design (Hardware, ARM, Epiphany).
Should i use Xilinx SDK to program the ARM cores, if so :
- the program will run under Ubuntu in ARM??
- What should i select in Hardware platform (i'm using parallella 7020)
Regards
- Xilinx SDK
- 1.jpg (163.32 KiB) Viewed 20618 times
Regards
