Parallella Community • View topic - generating epiphany code from templates, possible?
Re: generating epiphany code from templates, possible?
Postby piotr5 » Wed Aug 12, 2015 8:35 am
Postby dobkeratops » Wed Aug 12, 2015 11:30 am
dobkeratops
Postby dobkeratops » Wed Aug 12, 2015 4:48 pm
dobkeratops
Postby piotr5 » Thu Aug 13, 2015 8:18 am
Postby dobkeratops » Thu Aug 13, 2015 12:20 pm
dobkeratops
Postby sebraa » Thu Aug 13, 2015 12:37 pm
Postby dobkeratops » Thu Aug 13, 2015 12:47 pm
dobkeratops
Postby sebraa » Thu Aug 13, 2015 2:23 pm
I would say that latency doesn't matter here.
You have to differentiate between "local" accesses (core-local 32 KB memory) and "remote" accesses (anything else).
For local reads and writes, you won't experience any latency.
For remote writes, you won't experience any latency (assuming an idle mesh); writes are fire-and-forget. If the mesh is busy, there is round-robin arbitration.
For remote reads, you always have a huge latency, so you should avoid them in any case.
The available bandwidth is defined by the external eLink interface, not the memory you attach to the other side. So I wouldn't expect much difference. Also, FPGA RAM is expensive.
Postby dobkeratops » Thu Aug 13, 2015 3:25 pm
dobkeratops
Postby sebraa » Thu Aug 13, 2015 9:04 pm
