ePython error on first run for multicore code
Re: ePython error on first run for multicore code
Postby GlasierXplor » Fri Aug 04, 2017 2:24 pm
Hi sorry for such a late reply. Been busy with school work.
I have the correct image loaded - I am running the Kickstarter board.
The output I got when running `sudo modprobe epiphany` is as follows:
Code: Select all
elink 81000000.elink0: Could not get power supplies
And the output I got when running `dmesg` is as follows:
Code: Select all
[  164.187676] elink 81000000.elink0: elink: vdd regulator not ready, retry
[  164.187694] elink 81000000.elink0: Could not get power supplies
[  164.192247] elink 81000000.elink0: Deferring probe.
GlasierXplor
Postby olajep » Sat Aug 05, 2017 10:21 am
Seems i2C isn't working (could be b/c wrong bitstream) or the ISL9305 regulator is b0rken.
1. Please PM me the S/N number of your board. (Small white sticker in one of the corners)
2. Post the output of these commands:
Code: Select all
sudo mount /dev/mmcblk0p1 /mnt/
ls -l /mnt/parallella.bit.bin
md5sum /mnt/parallella.bit.bin
Code: Select all
ls /dev/i2c*
sudo apt-get install i2c-tools
sudo i2cdetect -y -r 0
// Ola
Postby GlasierXplor » Tue Aug 08, 2017 3:29 pm
Hi, the output are as follows:
Code: Select all
$ ls -l /mnt/parallella.bit.bin
-rwxr-xr-x 1 root root 4045568 Dec 15  2016 /mnt/parallella.bit.bin
Code: Select all
$ md5sum /mnt/parallella.bit.bin
dd5b98916885f02a49dad5f136a35bc6  /mnt/parallella.bit.bin
Code: Select all
$ ls /dev/i2c*
/dev/i2c-0
Code: Select all
$ sudo apt-get install i2c-tools
i2c-tools is already the newest version.
Code: Select all
$ sudo i2cdetect -y -r 0
#repeat printing of
cdns-i2c e0004000.i2c: timeout waiting on completion
GlasierXplor
Postby olajep » Wed Aug 09, 2017 1:30 pm
So the culprit is i2c, which needs the correct fpga bitstream loaded to work.
I believe you have a A101020 board, which comes with the Xilinx z7010 SoC.
The A101020 is not the kickstarter variant. The kickstarter model name is "A101040".
You can use this to verify which Zynq is on your board:
Code: Select all
$ cd /tmp
$ wget https://github.com/parallella/parallella-flash/raw/master/linux/getfpga
$ chmod +x getfpga
$ sudo ./getfpga
Download one of the P1600/P1601 compatible images here:
https://www.parallella.org/create-sdcard/
The image names end with z70x0 to identify which Zynq chip they're compatible with.
Please reply here if this solves the issue so we can mark this thread as solved
Ola
Postby GlasierXplor » Thu Aug 31, 2017 1:43 pm
Yes it works right now!
Just another question: I am not able to import normal Python modules when I run the script with
Code: Select all
epython filename
"Opening of Python file 'socket.py' failed, are you sure this file exists?"
Is there something I am supposed to do before importing the Python modules?
GlasierXplor
Postby GlasierXplor » Thu Aug 31, 2017 1:54 pm
I ran the code with sudo
Code: Select all
sudo epython filename
"/usr/bin/epython-host: error while loading shared libraries: libe-hal.so.0: cannot open shared object file: No such file or directory"
GlasierXplor
Postby bikasgaur » Fri Apr 13, 2018 1:28 pm
olajep, I've been encountering this very same "EPIPHANY_DEV file open failure" error upon running the code. Where shall I send the error logs? Can you please assist me to get it working?
bikasgaur
Postby olajep » Fri Apr 13, 2018 1:47 pm
bikasgaur wrote:olajep, I've been encountering this very same "EPIPHANY_DEV file open failure" error upon running the code. Where shall I send the error logs? Can you please assist me to get it working?
Most likely you are using the wrong disk image.
Instructions for determining which image to use can be found in the quick start guide:
https://www.parallella.org/quick-start/
Please provide:
1.) The exact model number on the board sticker
2.) The exact name/url of the image you are using
3.) Follow instructions above in this thread for running the getfpga script. What does it say?
4.) What does dmesg say?
Code: Select all
dmesg | grep "elink\|epiphany"
// Ola
