Memory Size Mismatch
PostPosted: Tue Sep 19, 2017 9:31 pm
by cwpdev
Probably (hopefully) something obvious here.
I'm getting a mismatch between the size of a declared variable type, and the size of the variables themselves. Specifically:
In the source code for my .elf file I've got:
volatile double q_0      SECTION(".text_bank2");
This is compiled with:
e-gcc -T ${ELDF} --std=gnu11 -O0 e_ants.c -o e_ants.elf -le-lib -lm
Where $ELDF=PATHTO/internal.ldf
Then in testing with e-gdb I'll try:
(gdb) p sizeof(double)
$36 = 8
(gdb) p sizeof(q_0)
$37 = 4
Obviously, 4 does not equal 8. This is cascading and causing value errors as I try to write values from the host to the devices. So far, I experienced the issue with doubles (4!=8) and shorts (4!=2). Basically, every global variable is getting a size of 4, instead of a size corresponding the its specific type.
Where am I screwing this up?
Re: Memory Size Mismatch
PostPosted: Wed Sep 20, 2017 2:11 am
by jar
I can't reproduce this. Here's what I did:
$ cat test.c
#include "e-lib.h"
$ e-gcc -g -c test.c -o test.o
$ e-gdb ./test.o
$1 = 8
(gdb) p sizeof(q_0)
$2 = 8
PostPosted: Wed Sep 20, 2017 2:56 am
by cwpdev
It was something obvious....
I was missing the -g from the compiler options...
:roll:
