Parallella Community • View topic - Purpose of HDMI
Purpose of HDMI
Purpose of HDMI
Postby adeshpande » Fri Jul 04, 2014 11:26 pm
Hi everyone,
What is the purpose of the micro HDMI to HDMI cable. Is that for connecting the board to a monitor? What if the monitor doesn't have an HDMI port?
adeshpande
Re: Purpose of HDMI
Postby xilman » Sat Jul 05, 2014 9:08 am
xilman
Re: Purpose of HDMI
Postby leon_heller » Sat Jul 05, 2014 9:40 am
I think that you can buy HDMI-VGA converters.
Leon Heller
G1HSM
leon_heller
Re: Purpose of HDMI
Postby greytery » Sat Jul 05, 2014 11:38 am
The HDMI to VGA adapters may require additional power for the 'active' signal conversion circuits in the adapter. Some use a separate USB cable for power (- NOT the Parallellla USB port!). Given that the Parallella is a bit sensitive about power levels, that may be critical.
Probably the better option is to buy a micro HDMI to DVI adapter (male or female) depending on what cables your monitor needs. These are more generally available (used for tablets, Kindles, etc) and require less, or negligible power to the plug (- but still best to check!)
Re: Purpose of HDMI
Postby paran » Sat Jul 05, 2014 1:25 pm
paran
Re: Purpose of HDMI
Postby gceline » Fri Jul 11, 2014 7:38 pm
Graham
Adapteva
gceline
