Serial as standard port
Postby paladrone » Mon Jul 21, 2014 4:01 pm
I have a parallella board, and I know that the Serial port come by default as a terminal, actually I can talk with my parallela via UART without problems.
However, I have a motion sensor and a wish to connect it to the parallela via UART, but I can't because is a console terminal.
Someone tried to disable the console TTPS0 and turn it as a standard serial port?
I don't know if it's a config issue, or I need to modify something else.
Thank you for you attention and comments.
Best regards
Luis
paladrone
Re: Serial as standard port
Postby 9600 » Mon Jul 21, 2014 6:16 pm
As far as I know you would need to:
  • Edit and recompile the devicetree file (to devicetree.dtb) so that the console is no longer put on /dev/ttyPS0
  • Disable the getty on PS0 (only required for headless image AFAIK) - see Ubuntu docs
Postby FHuettig » Mon Jul 21, 2014 6:39 pm
paladrone wrote:I have a parallella board, and I know that the Serial port come by default as a terminal, ... However, I have a motion sensor and a wish to connect it to the parallela via UART, but I can't because is a console terminal.
Someone tried to disable the console TTPS0 and turn it as a standard serial port? ...
The current devicetree and kernel settings no longer use the UART as a console like they used to. If you follow the latest "Creating a Parallella SD Card" then /dev/ttyPS0 will be free for your use.
Postby paladrone » Tue Jul 22, 2014 12:18 am
Thank you people, you are amazing.
Now the TTYPS0 works as a standard serial port. :D
FHuettig, you were right.
Regards
Luis
paladrone
