PSU - 5.2V Ok?
Posted:
Mon Aug 04, 2014 10:10 am
by AndyC
Hi Guys,
I have a 4A switching PSU here with variable DC 5-15V.
I just tested it with a meter and the lowest it goes is 5.2V, just checking that this should be ok with the board?
Cheers
Andy
Re: PSU - 5.2V Ok?
Posted:
Mon Aug 04, 2014 12:52 pm
by sebraa
Did you measure while the PSU was loaded? If not, try again with a load attached. Usually they need at lease some load to have the correct output voltage. Transformer-based PSUs are worse, though.
On the other hand, 5.2 volts should not be a problem.
Re: PSU - 5.2V Ok?
Posted:
Mon Aug 04, 2014 1:01 pm
by AndyC
Thanks for the reply.
It was tested unloaded. When I manage to get my heatsink attached I will give it a go and test it loaded.
Andy
Re: PSU - 5.2V Ok?
Posted:
Mon Aug 04, 2014 1:08 pm
by timpart
I have a power supply for two boards and with one board attached it supplies 5.1V. I had a look at the board schematic and traced the 5V line. I looked up the specs of the chips I found attached and they all had a max operating voltage of 5.5V. (Absolute max of 6.0 or 6.5 volts, but you don't want to go there.)
I may have missed one or misread a spec though. Perhaps someone from Adapteva could make an official comment.
With a 4A supply there is the risk that if you accidentally short out the board you could blow one of the 4A fuses. (The supply might be able to send out a bit more than 4A briefly.)
Re: PSU - 5.2V Ok?
Posted:
Mon Aug 04, 2014 1:22 pm
by AndyC
Actually on closer inspection this thing outputs 5A at 5V.
If I put a 3A fuse in the plug would that go before the board fuse?
Re: PSU - 5.2V Ok?
Posted:
Mon Aug 04, 2014 5:40 pm
by sebraa
Re: PSU - 5.2V Ok?
Posted:
Mon Aug 04, 2014 5:48 pm
by AndyC
Thanks for the info, I will give it a go and see.
Re: PSU - 5.2V Ok?
Posted:
Tue Aug 05, 2014 6:57 am
by timpart
Re: PSU - 5.2V Ok?
Posted:
Tue Aug 05, 2014 7:12 am
by AndyC
Thanks for the info.
I will use it for the moment, when I manage to get some kind of breakout for the GPIO I will get another PSU, just incase!
