by osteth » Tue Oct 14, 2014 12:12 am
OK, thanks for the assistance, I was assuming it wasn't going to fork that way right out of the box but I figured I would check. I will just run a couple jumper wires from unused ethernet pins back to the pads for +5v and gnd. I see no reason to add all sorts of extra connections to my headless units to complicate things when one connection will work. I will have to see if the POE effects the performance due to noise on the line but I see no reason why 5v would cause excessive noise.
