Re: RPi Camera bounty
Posted: Fri Mar 11, 2016 12:59 am
Hello to everybody,
I am finishing my Degree studies (so I am novice in this) and I have been trying to connect the RPi camera to the Parallella board during some time. I followed all the steps in the parallella-flash repo and I generated the BOOT.bin and the env.bin files. But then, when I connected the serial cable in order to upgrade the QSPI flash and followed the steps provided in that repo, there must have been something wrong. Since this moment, the board seems not to boot completely and after power on it, if I connect a serial cable to my PC, I see the uboot prompt "zynq-uboot>", like if the board could not to read the boot partition of the SD card. So I think there is a problem on the boot image of the QSPI flash. Also, the CR10 LED lights up and as I have read this should not occur for the SKU version of my board.
I have a Kickstarter version of the Parallella board with the SKU A101040.
I hope someone has got the solution to my problem or knows if there is any site where I can obtain the right BOOT.bin and env.bin files for correctly upgrading the QSPI flash.
Thank you in advance,
Samuel.
Samuel.
