Clock Epiphany
Clock Epiphany
Postby Gusvinhal » Wed Aug 02, 2017 10:12 pm
In some websites I found 600Mhz. In others, 1GHz ( http://www.adapteva.com/epiphanyiii/).
What is the clock of epiphany?
Thank You!
Gusvinhal
Re: Clock Epiphany
Postby jar » Wed Aug 02, 2017 10:22 pm
It's 600 MHz in the Parallella board by default. It can certainly be clocked higher or lower. You might want to clock lower for improved power efficiency.
Re: Clock Epiphany
Postby Gusvinhal » Wed Aug 09, 2017 2:46 pm
jar wrote:It's 600 MHz in the Parallella board by default. It can certainly be clocked higher or lower. You might want to clock lower for improved power efficiency.
Thank you!
Gusvinhal
