can you put a Forth compiler into each DSP core?
Moderator: timpart
Re: can you put a Forth compiler into each DSP core?
Postby svartalf » Fri Jun 23, 2017 4:02 pm
ASterbini wrote:(from a recent Parallella owner)
While I was looking for a mips forth to put on the Epiphany cores
I found gForth (with metacompiler and cross compiler) and mips-forth,
a threaded forth implemented for the Spim simulator.
Has anybody tried to put gForth on Epiphany?
No. I'll be honest, you're better off trying to implement in hand-tuned assembly- because gForth's going to be a bit largish being compiled from C code. Since I've not looked closely at the assembly architecture, unless there's something there to make Threading "easier" and to manage a stack, Forth's actually going to be a PAIN on it. More to the point, unless you've got good constructs for doing parallel programming in your dictionary, it's of less use than one would think
svartalf
Return to Forth
