PEC_NORTH/SOUTH Clustering Guidance Needed
Postby eric » Thu Mar 23, 2017 8:32 pm
I have been trying to get two (then more) Parallellas communicating via PEC_NORTH/PEC_SOUTH for some time, but keep hitting roadblocks. I am using the Porcupine boards with ribbon cables. The first hurdle is changing one of the Epiphany ROW/COL to (36,8).
I have edited the platform.hdf and changed CHIP_ROW to 36.
I have a jumper on the Porcupine, pulling YID0 up to 1.8V.
After reboot, running any software that accesses the Epiphany gives me:
e_open(): ECORE[0,0] MEM mmap failure.
And then a segmentation fault.
According to this thread (https://parallella.org/forums/viewtopic.php?f=23&t=3659), this combo has worked in the past. However their code does not run on the latest SDK. Any ideas out there?
eric
Re: PEC_NORTH/SOUTH Clustering Guidance Needed
Postby olajep » Sat Mar 25, 2017 3:02 pm
I don't think we currently support directly accessing another board's Epiphany chip from the ARM.
But communicating directly between Epiphany chips should work.
This should work (not tested):
1. Make sure the epiphany module is loaded with the 'nopm' (no power management) option.
Either manually via command line:
sudo rmmod epiphany
sudo modprobe epiphany nopm
or modprobe.d
https://wiki.archlinux.org/index.php/ke ... probe.d.2F
2. Don't change platform.hdf. Pretend CHIP_ROW is still 32.
3.
Create a epiphany program that writes to 0x90804000 (row=36 col=8 offset=0x4000)
Run it on the north board (unmodified CHIP_ROW).
4. On the south board you should be able to read out the value you wrote with the e-read command.
e-read 0 0 0x4000
// Ola
Postby eric » Mon Mar 27, 2017 2:13 pm
Thanks for the response Ola, I will follow your advice and post a follow-up.
-Eric
eric
Postby peteasa » Tue Mar 28, 2017 2:46 pm
See viewtopic.php?f=23&t=3659. It has also been proven with ribbon cables. Mailbox should allow communication with local arm core on both epiphany chips I think. None of this is proven with the latest elink / sdk but the steps that were taken to get it to work previously should still work. Expect to have to modify kernel driver and sdk code.
Peter.
peteasa
Postby olajep » Fri Mar 31, 2017 7:37 pm
eric wrote:Thanks for the response Ola, I will follow your advice and post a follow-up.
-Eric
Eric,
Had another look at the driver code.
The 'nopm' parameter wasn't respected everywhere (or rather the behavior wasn't 100% consistent).
Fixed in this commit
https://github.com/parallella/parallell ... 1a16a4965d
epiphany: Don't disable disconnected chip elinks in nopm mode
In epiphany_reset():
Don't enable clock gating and don't try to disable disconnected elinks
when power management is disabled.
Attached new kernel module w/ fix
epiphany.ko.zip
(98.52 KiB) Downloaded 946 times
sudo mv /lib/modules/4.6.0+/kernel/drivers/misc/epiphany.ko  /lib/modules/4.6.0+/kernel/drivers/misc/epiphany.ko.bak
unzip epiphay.ko.zip
sudo mv epiphany.ko /lib/modules/4.6.0+/kernel/drivers/misc/epiphany.ko
sudo rmmod epiphany
Return to Clustering
