OpenGL ES 2.0 for Parallella with RPi
Re: OpenGL ES 2.0 for Parallella with RPi
Postby shodruk » Fri Jan 24, 2014 11:49 am
I ordered Odroid U3 too. :)
The network bandwidth will be a bottleneck as well (because it's also 100M),
but we will be able to use more complex shader and model with it.
Postby TrikingSheep » Fri Jan 24, 2014 1:17 pm
shodruk wrote:The network bandwidth will be a bottleneck as well (because it's also 100M),
Might have to upgrade to the XU(2) with the USB3 to GBit Ethernet to cope with the bottleneck, but the U2 is a good start.
Kind Regards,
Julian.
TrikingSheep
Postby Janos » Fri Jan 24, 2014 1:22 pm
Ah thanks Julian! I had just started to think about that bandwidth question.
http://www.tsbt.co.uk
Janos
Postby TrikingSheep » Sun Jan 26, 2014 4:17 pm
shodruk wrote:The network bandwidth will be a bottleneck as well (because it's also 100M).
How about using a dedicated USB to Ethernet adapter just for the graphics? and wire it directly?
Or we could use the onboard Ethernet and then use the USB adapter for other Ethernet traffic.
I know it won't be as good as Gigabit, but it's a halfway house.
Kind Regards,
Julian.
TrikingSheep
Postby TrikingSheep » Mon Jan 27, 2014 11:28 am
I have found a USB2 to Gigabit Ethernet adapter. This should give up to 480Mb/s throughput. All we need now is to see if we need drivers or if it works out of the box.
Is this enough???
Kind Regards,
Julian.
TrikingSheep
Postby shodruk » Mon Jan 27, 2014 11:41 am
TrikingSheep wrote:How about using a dedicated USB to Ethernet adapter just for the graphics? and wire it directly?
That's a good idea, but the program may become complex.
I am also interested in UDOO Quad, it has a gigabit ethernet, Vivante GC2000 GPU, and SATA.
However, it is a bit expensive ($135), and I don't know whether it supports OpenGL ES 2.0 on normal linux.
http://www.udoo.org/
TrikingSheep wrote:I have found a USB2 to Gigabit Ethernet adapter. This should give up to 480Mb/s throughput. All we need now is to see if we need drivers or if it works out of the box.
Is this enough???
I suppose the adapter can only gain less than 100Mbps in actuality.
But, I'll try with ASIX AX88179 chip USB 3.0/2.0 Gigabit Ethernet adapter.
Postby TrikingSheep » Tue Jan 28, 2014 2:32 pm
shodruk wrote:I am also interested in UDOO Quad, it has a gigabit ethernet, Vivante GC2000 GPU, and SATA.
I have found this:
The LCD8000-97CLCD8000-97C is a portable 9.7” LVDS display module with capacitive multi-touch* interface for SABRE LiteSABRE Lite and MarS BoardMarS Board, featuring the Freescale’s powerful i.MX 6 ARM Cortex-A9 Quad & Dual Core multimedia application processors respectively. The display module integrates a capacitive multi-touch screen with an LVDS interface and supports the resolution of 1024×768 with 262K colors to provide an excellent & smooth touch interface experience.
The SABRE LiteSABRE Lite is a development board for i.MX 6Quad built to Freescale® SABRE LiteSABRE Lite design is a low-cost development platform based on Freescale’s i.MX 6Quad processor based on ARM Cortex-A9 architecture which encompasses a quad-core platform running up to 1 GHz with 1 MB of L2 cache and 64-bit DDR3 or 2-ch., 32-bit LPDDR2 support. Integrated FlexCAN, MLB busses, PCI Express® and SATA-2 provide excellent connectivity, while integration of LVDS, MIPI display port, MIPI camera port and HDMI v1.4.
http://www.element14.com/community/docs ... 114-Embest
Not sure, but might be useful, just a tad expensive.
Kind Regards,
Julian.
TrikingSheep
Postby shodruk » Wed Jan 29, 2014 3:44 pm
MarS Board looks good too.
Gigabit Ethernet, Vivante GC2000, $99
http://www.embest-tech.com/shop/star/marsboard.html
Postby TrikingSheep » Tue Feb 18, 2014 8:33 am
shodruk wrote:I ordered Odroid U3 too. :)
Hi Shodruk,
Have yo got your U3? and have you managed to get it to work with OpenGL ES 2.0?
Do we need to start a new thread for the U3?
Kind Regards,
Julian.
TrikingSheep
Postby shodruk » Wed Feb 19, 2014 8:26 am
TrikingSheep wrote:Hi Shodruk,
Yes it has arrived. I've also got an ASIX AX88179 chip USB 3.0 Ethernet adapter.
But I'm busy for now to build my new project for Parallella. ;)
I'm going to port gl-server to Odroid-U3 after that.
