Some naive questions about Epiphany assembly
Posted: Fri Jun 26, 2015 5:36 pm
Hi there,
I'm writing some simple assembler programs, and I have run across some problems with compiling and understanding the code in the Epiphany architecture reference manual. There are a few snippets of code that I couldn't get to work. These are:
- The LDR (POSTMODIFY) example on pp 103 fails to compile with the error ldrdpm.s:3: Error: unrecognised form of instruction 'ldrs r31,[r2],#1'
- The LDR (DISPLACEMENT-POSTMODIFY) example on pp 105 fails to compile with the error ldrpm.s:3: Error: unrecognised form of instruction 'ldrs r31,[r2],r1'
- The STR (POSTMODIFY) example on pp 121 fails to compile with the error str_pm.s:3: Error: unrecognised form of instruction 'strs r31,[r2],r1'
- The STR (DISPLACEMENT-POSTMODIFY) example on pp 122 fails to compile with the error str_dpm.s:3: Error: unrecognised form of instruction 'strs r31,[r2],#2
Any form of load or store that deals with shorts seems to result in a syntax error. Have I misunderstood something here?
Many thanks!
Sarah
Many thanks!
Sarah
