Parallella Community • View topic - Edited: Cannot boot Zedboard from the 13020600 image
Re: Edited: Cannot boot Zedboard from the 13020600 image
Postby ysapir » Thu Jul 18, 2013 1:29 am
Ivan,
As Andreas noted, the Hello-World output is as expected from the E64 board. As for the matmul - if you are running the latest eSDk (5.13.07.10), then this example uses a feature of the chip that was not supported in the previous firmware revisions. Please follow the instructions in the UPDATE 2 of the release announcement:
viewtopic.php?f=13&t=422&p=2614#p2623
Please make sure that you backup the old bitstream before updating to the new! If the new one does not work on your board, it is the shortest path to restoring the current state.
Postby mipt98 » Thu Jul 18, 2013 7:26 pm
Hi guys,
Yes, matmul works with the latest bitstream -- thanks! I have posted a question regarding somewhat worse than in the quick start guide timings on the SDK board .
Andreas: Unfortunately I don't know what is different about the kernel I compiled. I've received the SD you recommended from Amazon, and the default image at doesn't boot either. Maybe it's a good idea to post another one with the new kernel.
-Ivan
mipt98
