Parallella to laptop
PostPosted: Tue Jun 06, 2017 6:50 am
by parimey
I am totally new with parallella. I have a parallella board. I have read the manuals and gone through the quick start process but I couldn't find the way to connect parallella to my HP laptop. Please tell me if I can connect parallella with laptop or not? If yes the how?
Thank you very much in advance!! :)
Re: Parallella to laptop
PostPosted: Tue Jun 06, 2017 9:09 pm
by sebraa
You take an Ethernet cable, plug one end into the Parallella's Ethernet port, then plug the other end into your laptop's Ethernet port.
PostPosted: Sat Jun 17, 2017 2:08 pm
by parimey
@sebraa and how can I login to parallella then?
PostPosted: Sat Jun 17, 2017 4:07 pm
by polas
Hi - yup, I would suggest connecting the Parallella via ethernet to your router & then you can SSH in (by default the username is parallella, password is parallella.) If you are on Windows then Putty is a good SSH client to use. You will need to know the IP address of the Parallella board, you can find this out by looking at the DHCP table of your router (typically via the admin web interface.)
Nick
