Parallella Community • View topic - Internet Sharing, ssh
Postby rheiland » Wed Apr 08, 2015 1:48 am
Slightly off-topic, but just curious if anyone has successfully used OSX Internet Sharing to connect/ssh (via ethernet) to a Parallella? It was straightforward when I did it with a RPi, but no such luck for the Parallella. [OSX Yosemite]
thanks,
rheiland
Re: Internet Sharing, ssh
Postby boeserbaer » Wed Apr 08, 2015 5:28 pm
Hi Randy,
I ran into some issues with internet sharing also. At this point I am running an Ubuntu 14.04 VM and using it to share the connection to the parallella. I believe that the OS X sharing worked after a reboot. Though to find the IP address of the parallel board though. I ended up looking at the IP address of the ethernet port on my mac, and pinging around.
One of these days I will write a small UDP broadcast responder so that the parallel can identify itself. Or more likely, find a package someone else wrote with this in mind.
Best Regards, Mike
boeserbaer
Postby 9600 » Thu Apr 09, 2015 8:30 am
Postby rheiland » Fri Apr 10, 2015 12:08 am
Thanks for the replies! After switching to my new uSD card with the new (2015) headless image (and discovering the forum post titled 'Parallella SSH Access' to see that I needed to ssh to 'parallella' and not 'linaro'), I was able to get in. Seeing this was the hopeful sign:
cat /private/var/db/dhcpd_leases
name=parallella
ip_address=192.168.2.2
hw_address=1,4:4f:8b:0:24:9d
identifier=1,4:4f:8b:0:24:9d
lease=0x55285ce2
Previously, I was trying to ssh into my old (2014) desktop image and never could.
thanks, Randy
rheiland
