Parallella Community • View topic - Broken USB connector
Postby manklee » Thu Mar 19, 2015 5:53 pm
For whatever reasons, the USB connector on my Parallella is broken and has fallen off the board! As far as I can tell, the board is still working. I turn it on and I can see it booting until it waits for someone to log in. Assuming the ethernet port is still working, can I use some sort of a ethernet terminal program on another computer to log into the Parallella?
Thanks in advance for helping me out.
Man Lee
manklee
Re: Broken USB connector
Postby 9600 » Fri Mar 20, 2015 11:02 am
Yes, you should be able to use SSH. A client for which tends to come installed with Linux distros and IIRC Mac also, and if you are running Windows you could use PuTTY or similar.
Postby manklee » Wed Apr 15, 2015 6:11 am
Thanks for the advice Andrew. I was able to use PuTTY to log in to the board.
manklee
