Parallella Community • View topic - Is this boot sequence OK?
Postby leon_heller » Sun Mar 16, 2014 11:16 am
Leon Heller
G1HSM
leon_heller
Re: Is this boot sequence OK?
Postby Janos » Sun Mar 16, 2014 5:41 pm
Looks fine to me. What does not work?
p.s. you might want to post long text like this in code tags.
Janos
Postby leon_heller » Sun Mar 16, 2014 6:03 pm
Thanks.
I've used code tags.
USB has stopped working, and there is an intermittent supply fault causing the board to reboot when it is touched or moved.
Leon Heller
G1HSM
leon_heller
Postby Janos » Sun Mar 16, 2014 6:12 pm
Janos
Postby leon_heller » Sun Mar 16, 2014 6:21 pm
It's something internal on the board.
Leon Heller
G1HSM
leon_heller
Postby 9600 » Sun Mar 16, 2014 8:10 pm
Definitely the right size barrel connector on the PSU? I experienced similar issues when I used one where the inside diameter was ever so slightly too large.
Postby leon_heller » Sun Mar 16, 2014 8:32 pm
Yes, 5.5 mm/2.1 mm. I've tried two supplies in case the cable or the connector was faulty. They work OK with other boards, such as the BBB.
Leon Heller
G1HSM
leon_heller
Users browsing this forum: No registered users and 70 guests
