Parallella Board not bootin
Re: Parallella Board not bootin
Postby ticso » Wed May 07, 2014 9:51 pm
This is not just with the bps speed on the client side.
Today I've hooked up one of my board to uart, to do some advanced tests and was surprised that the output is not completely clean 115200bps.
I'm used to see a tiny powerup glitch, but this much more then expected.
My board is booting fine and this is what I get on uart:
dL<88<<88<<88<88x<88p<<88x<88q<<88x<88p<<88q<<88q<<888p<<8dYyt4y55]y5pt4YyyYtYYtYy5qt5]yt5YYt5xTYYYy5t5y5t5YYt4ypt5yYT4YYxYY5yTYyYTY]xtYYt5YyYTYYyt4yyYTYYY5YyTyYt5YyYt5YYt5ypt5YYxt5Yy5y5xxYYt5y
U-Boot 2012.10-00003-g792c31c (Jan 03 2014 - 12:24:08)
I2C: ready
DRAM: 992 MiB
WARNING: Caches not enabled
MMC: SDHCI: 0
SF: Detected N25Q128 with page size 64 KiB, total 16 MiB
In: serial
Out: serial
Err: serial
Net: zynq_gem
Hit any key to stop autoboot: 0
Configuring PL and Booting Linux...
Device: SDHCI
Manufacturer ID: 82
OEM: 4a54
Tran Speed: 50000000
Rd Block Len: 512
SD version 2.0
High Capacity: Yes
Capacity: 7.4 GiB
Bus Width: 4-bit
reading parallella.bit.bin
You clearly see that something glibberisch is send before something is send in 115200 bps.
However - the u-boot output is also send without an SD card inserted - unless that gliberisch stopped your terminal from printing, which my xterm fortunately didn't.
I've tried a few standard bps rates, but couldn't read the first bit pattern.
Will try to get it on scope later today to measure what frequency it is.
ticso
Postby ticso » Wed May 07, 2014 10:17 pm
It starts with long time low voltage, then many bursts of 5MHz output, high voltage, then normal boot output.
The bursts itself are split into blocks with 5MHz and 2.5ms low voltage pauses.
For me it looks a bit like SPI clock signal or such, but why are those on console uart?
ticso
Postby Gravis » Wed May 14, 2014 4:14 pm
ticso wrote:You clearly see that something glibberisch is send before something is send in 115200 bps.
i get the same type of garbage which may be some sort of binary data dump. the world may never know. i use GtkTerm and it works fine.
Postby jeff.seibert » Fri May 23, 2014 10:06 pm
I ordered an accessory bundle from Adapteva and it just arrived today. The only problem is that even with the cables they sent me, I'm still having issues. With their power cable the LED is now flashing. Any suggestions?
Thank you,
jeff.seibert
Postby pilloutche » Sun Jul 06, 2014 8:52 pm
I also experienced the problem (parallella board didn't respond correctly on putty).
First of all, check and check again your power supply ! don't use an unregulated power. The correct voltage (written 5V on the transformer) and correct current (>2A) is unsufficient to say that it's a good power supply because you need voltage regulation.
Secondly, remember that the parallella board UART have 3.3V voltage's level. check that your USB to serial converter is compatible with 3.3V UART unless, you will see uncomprehensive messages written in putty (or any other hyperterminal) even with the correct 115200 bauds.
Thirdly, don't think that a fan is an option because you really need one every time the board is powered.
return back to say if it works. Hope that will help.
pilloutche
Postby laughterwym » Thu Aug 28, 2014 7:46 am
I got the same problem. Jumbled string on RX/TX.
FTDI USB serial converter is connected to TP1. 115200 8N1, no parity, no flow control. I also have tried several serial terminal tools - Minicom, putty, GtkTerm, Teraterm. I have tried Xon/Xoff for flow control as well.
I used the inbox PSU and large heat sink. A fan is attached with separated power supply.
The board will failed in booting into Linaro occasionally. Fail/Pass rate: 4/6. That's why I want to check the booting message.
Is there any update on this post?
Thanks!
laughterwym
Postby bobblestiltskin » Wed Oct 01, 2014 7:47 pm
My board does also not appear to boot - I use a 5A power supply and see one green light. I get no hdmi output. I have tried to attach a known good serial cable, and see *no* output with the correct gtkterm settings - I have swapped the green and white serial cables too, this with and without an attached sdcard. I am at a loss as to where to look next. Any suggestions gratefully received!
bobblestiltskin
Postby bobblestiltskin » Mon Nov 03, 2014 6:51 pm
I replaced my power supply with this one -> http://uk.rs-online.com/web/p/plug-in-p ... ly/7066502 - after some support from adapteva and now mine works fine :D
bobblestiltskin
