Parallella Community • View topic - Trouble with booting
Postby darknist » Wed Jun 11, 2014 5:21 am
darknist
Re: Trouble with booting
Postby gceline » Thu Jun 12, 2014 3:18 pm
Check you have the correct files copied to the BOOT sector of the SD card. This looks like the board is alive, but not booting. HDMI and Ethernet will only work after boot.
Graham
Adapteva
gceline
Postby darknist » Sun Jun 15, 2014 6:28 am
Thanks for the reply, I had already tried re-writing the image to the SD card,
and tried again after reading your post. No changes.
Any other thoughts on this? I'm really stuck.
darknist
Postby greytery » Sun Jun 15, 2014 10:42 am
Postby greytery » Sun Jun 15, 2014 11:00 am
@ darknist - you don't mention using a powered USB hub in your set up
BTW - like your fan picture :idea: I'm using the same longer stand-offs but I will need to have the 80cm fan at 90 degrees ** to cool a stacked pair of boards.
( ** geometry not temp!)
Postby gceline » Mon Jun 16, 2014 12:23 pm
Graham
Adapteva
gceline
Users browsing this forum: No registered users and 20 guests
