HDMI Not Working
Re: HDMI Not Working
Postby MacTuxLin » Mon Jul 21, 2014 3:44 pm
9600 wrote:...I'm wondering if editing the X server config to set a particular mode might help. ISTR that Shodruk has previously posted a how-to for doing this.
Thank you Andrew. Yes, after changing the resolution down to 1280x720 via ssh & reboot, the display was up & running!
And, thanks to all especially Diana for your constant follow-up.
MacTuxLin
Postby 9600 » Mon Jul 21, 2014 6:19 pm
Glad to hear you are now up and running :)
Postby gceline » Wed Jul 23, 2014 1:27 pm
If the system is booting, then it will get an IP address via DHCP and should be pingable - else there is a basic issue with the boot and it is not even getting started.
Graham
Adapteva
gceline
Postby plus » Fri Aug 22, 2014 1:42 pm
Hi all!
Same problem here: I burned the ubuntu-lxde-14.03.06-p16g1.img image, I can access it by ssh but I got no hdmi signal.
Power led is green on, ethernet green led is on and stable and the amber one is blinking sometimes as it should be I guess...
I tried this xorg.conf:
Section "Device"
Identifier "Card0"
Driver "modesetting"
Option "ShadowFB" "True"
Option "SWCursor" "True"
Option "HWCursor" "False"
EndSection
Section "Screen"
Identifier "Screen0"
Device "Card0"
SubSection "Display"
Modes "1280x720"
EndSubSection
EndSection
Nothing again....:( Could you please give me some directions? I want to use my parallela as a desktop machine.
p.s.: I noticed that xorg.conf file was empty before my editing above
I got an asus hd multimedia monitor
EDIT: parallela board doesn't work with my asus hd monitor but it worked with a recent lg hd tv. The NON COMPATIBLE monitor is: ASUS VE228HR multimedia
Could you please try to improve the hdmi compatibility with the next ubuntu images? thanx.
thanx, all the best.
massimiliano
plus
Postby aolofsson » Fri Aug 22, 2014 2:28 pm
The "offical" image is this one.
http://downloads.parallella.org/ubuntu/ ... sty/image/
Can you help out and tell me why you used the ubuntu-lxde-14.03.06-p16g1.img?
Seems like we may need to clean up some links...
Postby plus » Mon Aug 25, 2014 9:44 am
aolofsson wrote:The "offical" image is this one.
thanx Andreas. I tried the official image but I get the same no hdmi signal. I changed nothing inside the original xorg.conf that comes within the image. Everything seems to be fine except for the video output 'cause I can reach parallela board by ssh and all the leds are ok. Some tips for fixing the hdmi issue? My asus hd monitor is fine with an odroid arm device, cables are ok.
EDIT: Tried the 1280 resolution mode editing the xorg.conf. via ssh, nothing new: HDMI NO SIGNAL :(
please help
all the best
plus
Postby pgater » Mon Aug 25, 2014 7:39 pm
I got my image from here : - ftp://ftp.parallella.org/sd_images
That link is still active.
I was blaming my HDMI problems on my monitor, but on reading the above have downloaded the current file :D . However while I have no problem downloading, unzipping and writing ubuntu-lxde-14.03.06-p16g1.img to the flash drive and getting the computer to boot and appear on the network, I cannot say the same for the official current image :? .
I have now downloaded the current image 4 times now and still do not get a bootable image on the flash drive :!: . I have rewritten ubuntu-lxde-14.03.06-p16g1.img to the flash card and the computer boots as I am writing this message :D
I am using Windows Vista 64 bit ultimate, winzip and win32 disk imager. The flash drive/card was supplied in the accessory kit I bought.
Could the current image be checked please?
Paul
pgater
Postby m0n5t3r » Tue Aug 26, 2014 6:39 pm
Ok, so I managed to get the necessary stuff for my Parallella a month after receiving it, and HDMI is no worky:
1. Parallella SKU? (SKU A1010X0?)
SKUA101020 (edit: I just checked, the chip is definitely XC7Z010, not sure what's with the SKU; also, that aluminium adhesive pad on the heatsink doesn't seem to make contact very well, it's sticking mostly around the edges)
2. What type of fan are you using? (e.g. 40mm, 5V, 0.2A)
100mm USB fan, powered separately, stock heatsink stays cool to the touch (haven't had time to machine an adapter for a chipset-style 50x50mm cooler - those giant caps are annoying)
3. What PSU are you using? (e.g. 5V, 3A)
5V, 2.5A
4. What HDMI cable are you using? (e.g. microHDMI-HDMI, microHDMI-DVI)
microHDMI-HDMI->HDMI-DVI adapter
5. What monitor are you using?
Dell 2001FP - another HDMI-DVI cable works fine with desktop (some cheap Radeon card with HDMI output) and Raspberry Pi; I have another DVI-DVI cable somewhere, so I can test the adapter when / if I find it, but I kinda doubt it's the adapter or the cable (both are brand new)
6. Linux image? (e.g. ubuntu-14.04-140611.img.gz)
7. Kernel? (e.g. kernel-hdmi-140603.tgz)
kernel-hdmi-default.tgz, as linked from the quickstart page (symlink to kernel-hdmi-140603.tgz? http://downloads.parallella.org/boot/linux/ says they have the same mtime / size)
Code: Select all
root@linaro-nano:~# uname -a
Linux linaro-nano 3.12.0-g0bc9c3a-dirty #6 SMP PREEMPT Wed Jan 29 10:25:25 CET 2014 armv7l armv7l armv7l GNU/Linux
8. FPGA bitstream? (e.g. parallella_e16_hdmi_gpiose_7020.bit.bin)
parallella_e16_hdmi_gpiose_7010.bit.bin
9. Login via ssh, type this command and post the output. (Make sure you are connecting the monitor to the Parallella)
basically the same thing as whitlom on page 2: it thinks HDMI is disconnected (it's definitely not, and the monitor goes into standby when the cable is connected instead of displaying the usual colour test image that bounces around when there's nothing connected)
Code: Select all
[    14.524]
X.Org X Server 1.15.1
Release Date: 2014-04-13
[    14.525] X Protocol Version 11, Revision 0
[    14.525] Build Operating System: Linux 3.2.0-58-highbank armv7l Ubuntu
[    14.525] Current Operating System: Linux linaro-nano 3.12.0-g0bc9c3a-dirty #6 SMP PREEMPT Wed Jan 29 10:25:25 CET 2014 armv7l
[    14.525] Kernel command line: root=/dev/mmcblk0p2 rw rootfstype=ext4
[    14.526] Build Date: 16 April 2014  01:41:53PM
[    14.526] xorg-server 2:1.15.1-0ubuntu2 (For technical support please see http://www.ubuntu.com/support)
[    14.526] Current version of pixman: 0.30.2
[    14.526]    Before reporting problems, check http://wiki.x.org
   to make sure that you have the latest version.
[    14.526] Markers: (--) probed, (**) from config file, (==) default setting,
   (++) from command line, (!!) notice, (II) informational,
   (WW) warning, (EE) error, (NI) not implemented, (??) unknown.
[    14.528] (==) Log file: "/var/log/Xorg.0.log", Time: Tue Aug 26 18:05:52 2014
[    14.550] (==) Using config file: "/etc/X11/xorg.conf"
[    14.550] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[    14.568] (==) No Layout section.  Using the first Screen section.
[    14.568] (**) |-->Screen "Screen0" (0)
[    14.568] (**) |   |-->Monitor "<default monitor>"
[    14.569] (**) |   |-->Device "Card0"
[    14.570] (==) No monitor specified for screen "Screen0".
   Using a default monitor configuration.
[    14.570] (==) Automatically adding devices
[    14.570] (==) Automatically enabling devices
[    14.570] (==) Automatically adding GPU devices
[    14.603] (WW) The directory "/usr/share/fonts/X11/cyrillic" does not exist.
[    14.603]    Entry deleted from font path.
[    14.603] (WW) The directory "/usr/share/fonts/X11/100dpi/" does not exist.
[    14.604] (WW) The directory "/usr/share/fonts/X11/75dpi/" does not exist.
[    14.604]    Entry deleted from font path.
[    14.605] (WW) The directory "/usr/share/fonts/X11/100dpi" does not exist.
[    14.605]    Entry deleted from font path.
[    14.605] (WW) The directory "/usr/share/fonts/X11/75dpi" does not exist.
[    14.605] (==) FontPath set to:
   /usr/share/fonts/X11/misc,
   /usr/share/fonts/X11/Type1,
   built-ins
[    14.606] (==) ModulePath set to "/usr/lib/arm-linux-gnueabihf/xorg/extra-modules,/usr/lib/xorg/extra-modules,/usr/lib/xorg/modules"
[    14.606] (II) The server relies on udev to provide the list of input devices.
   If no devices become available, reconfigure udev or disable AutoAddDevices.
[    14.606] (II) Loader magic: 0xb6f18f18
[    14.606] (II) Module ABI versions:
[    14.606]    X.Org ANSI C Emulation: 0.4
[    14.606]    X.Org Video Driver: 15.0
[    14.606]    X.Org XInput driver : 20.0
[    14.606]    X.Org Server Extension : 8.0
[    14.609] (II) xfree86: Adding drm device (/dev/dri/card0)
[    14.611] Initializing built-in extension Generic Event Extension
[    14.611] Initializing built-in extension SHAPE
[    14.611] Initializing built-in extension MIT-SHM
[    14.612] Initializing built-in extension XInputExtension
[    14.612] Initializing built-in extension XTEST
[    14.612] Initializing built-in extension BIG-REQUESTS
[    14.612] Initializing built-in extension SYNC
[    14.612] Initializing built-in extension XKEYBOARD
[    14.612] Initializing built-in extension XC-MISC
[    14.613] Initializing built-in extension SECURITY
[    14.613] Initializing built-in extension XINERAMA
[    14.613] Initializing built-in extension XFIXES
[    14.613] Initializing built-in extension RENDER
[    14.613] Initializing built-in extension RANDR
[    14.613] Initializing built-in extension COMPOSITE
[    14.613] Initializing built-in extension DAMAGE
[    14.614] Initializing built-in extension MIT-SCREEN-SAVER
[    14.614] Initializing built-in extension DOUBLE-BUFFER
[    14.614] Initializing built-in extension RECORD
[    14.614] Initializing built-in extension DPMS
[    14.614] Initializing built-in extension Present
[    14.614] Initializing built-in extension DRI3
[    14.615] Initializing built-in extension X-Resource
[    14.615] Initializing built-in extension XVideo
[    14.615] Initializing built-in extension XVideo-MotionCompensation
[    14.615] Initializing built-in extension SELinux
[    14.615] Initializing built-in extension XFree86-VidModeExtension
[    14.615] Initializing built-in extension XFree86-DGA
[    14.616] Initializing built-in extension XFree86-DRI
[    14.616] Initializing built-in extension DRI2
[    14.616] (II) LoadModule: "glx"
[    14.630] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[    14.727] (II) Module glx: vendor="X.Org Foundation"
[    14.727]    compiled for 1.15.1, module version = 1.0.0
[    14.727]    ABI class: X.Org Server Extension, version 8.0
[    14.727] (==) AIGLX enabled
[    14.727] Loading extension GLX
[    14.727] (II) LoadModule: "modesetting"
[    14.737] (II) Loading /usr/lib/xorg/modules/drivers/modesetting_drv.so
[    14.743] (II) Module modesetting: vendor="X.Org Foundation"
[    14.743]    compiled for 1.15.0, module version = 0.8.1
[    14.743]    Module class: X.Org Video Driver
[    14.743]    ABI class: X.Org Video Driver, version 15.0
[    14.744] (II) modesetting: Driver for Modesetting Kernel Drivers: kms
[    14.744] (++) using VT number 7
[    14.765] (II) modesetting(0): using drv /dev/dri/card0
[    14.768] (==) modesetting(0): Depth 24, (==) framebuffer bpp 32
[    14.769] (**) modesetting(0): Option "SWcursor" "True"
[    14.769] (**) modesetting(0): Option "ShadowFB" "True"
[    14.769] (==) modesetting(0): RGB weight 888
[    14.769] (==) modesetting(0): Default visual is TrueColor
[    14.769] (II) modesetting(0): ShadowFB: preferred NO, enabled YES
[    14.772] (II) modesetting(0): Output HDMI-0 has no monitor section
[    14.774] (II) modesetting(0): EDID for output HDMI-0
[    14.775] (II) modesetting(0): Output HDMI-0 disconnected
[    14.775] (WW) modesetting(0): No outputs definitely connected, trying again...
[    14.775] (WW) modesetting(0): Unable to find connected outputs - setting 1024x768 initial framebuffer
[    14.775] (II) modesetting(0): Using default gamma of (1.0, 1.0, 1.0) unless otherwise stated.
[    14.775] (==) modesetting(0): DPI set to (96, 96)
[    14.775] (II) Loading sub module "fb"
[    14.775] (II) LoadModule: "fb"
[    14.782] (II) Loading /usr/lib/xorg/modules/libfb.so
[    14.791] (II) Module fb: vendor="X.Org Foundation"
[    14.791]    compiled for 1.15.1, module version = 1.0.0
[    14.791]    ABI class: X.Org ANSI C Emulation, version 0.4
[    14.791] (II) Loading sub module "shadow"
[    14.791] (II) LoadModule: "shadow"
[    14.794] (II) Loading /usr/lib/xorg/modules/libshadow.so
[    14.800] (II) Module shadow: vendor="X.Org Foundation"
[    14.800]    compiled for 1.15.1, module version = 1.1.0
[    14.800]    ABI class: X.Org ANSI C Emulation, version 0.4
[    14.801] (==) Depth 24 pixmap format is 32 bpp
[    14.847] (==) modesetting(0): Backing store enabled
[    14.847] (==) modesetting(0): Silken mouse enabled
[    14.848] (II) modesetting(0): RandR 1.2 enabled, ignore the following RandR disabled message.
[    14.849] (==) modesetting(0): DPMS enabled
[    14.849] (WW) modesetting(0): Option "HWCursor" is not used
[    14.849] (--) RandR disabled
[    14.905] (II) SELinux: Disabled on system
[    14.911] (II) AIGLX: Screen 0 is not DRI2 capable
[    14.911] (EE) AIGLX: reverting to software rendering
[    15.077] (II) AIGLX: Loaded and initialized swrast
[    15.078] (II) GLX: Initialized DRISWRAST GL provider for screen 0
[    15.081] (II) modesetting(0): Damage tracking initialized
[    15.283] (II) XKB: reuse xkmfile /var/lib/xkb/server-B20D7FC79C7F597315E3E501AEF10E0D866E8E92.xkm
[    15.997] (II) config/udev: Adding drm device (/dev/dri/card0)
[    15.998] (II) config/udev: Ignoring already known drm device (/dev/dri/card0)
[    16.110] (II) modesetting(0): Disabling kernel dirty updates, not required.
m0n5t3r
Postby m0n5t3r » Wed Aug 27, 2014 2:14 pm
All righty, the plot thickens: I tested with my other monitor (also from the last decade) and a bunch of monitors at work (microHDMI-HDMI -> HDMI-DVI adapter), no luck; tried the big-ass TV in a conference room (it has 2 HDMI inputs), it worked.
The adapter is female HDMI to 24+1 DVI (unlike my other HDMI-DVI cable, this one has all of the DVI pins populated); is this the wrong adapter, or is the Parallella not outputting the right signals for DVI?
Edit: the adapter is fine, I just tested (PC -> HDMI cable -> HDMI-DVI adapter); so, it must be Parallella not providing the right signals somehow. The question is: is this fixable in the code / zynq bitstream, or am I out of luck? I assume the HDMI transmitter knows how to send what's needed, but maybe it's hardwired in a certain configuration, or it only implements part of the spec...
m0n5t3r
Postby rpflaum » Wed Aug 27, 2014 5:36 pm
I have tried three different DVI monitors and not had luck with any of them. However I have been able to use 2 different HDMI input monitors and have not had any problems.
rpflaum
