HDMI sound not working with new bit.bin
Postby shodruk » Wed Aug 13, 2014 1:13 pm
I still can't get sounds through HDMI using parallella_e16_hdmi_gpiose_7020.bit.bin. :?
SMPlayer, aplay and other sound programs hang when playing sounds via HDMI.
How can I solve this?
(I have no problem with rel.14.02.06/parallella.bit.bin)
using these files.
8676219f8067cab68589f0ab7a105651 ubuntu-14.04-140611.img.gz
8eab4b6228e32a0432279f76de51300f kernel-hdmi-140603.tgz
d920ca30ce6c1a9b1da841fa18e5dda3 parallella_e16_hdmi_gpiose_7020.bit.bin
Parallella board: A101040
I've tested with 3 different HDMI monitors (true HDMI).
Has anyone succeeded to get HDMI sound working with parallella_e16_hdmi_gpiose_7020.bit.bin?
I really want to solve this problem.
Please help me.
Re: HDMI sound not working with new bit.bin
Postby FHuettig » Wed Aug 13, 2014 10:23 pm
Hi Shodruky, I thought the problem happened with the new SD image rather than the bitstream, so I was blaming software. :o Are you saying below that you can take the current OS image and get sound to work or fail by changing -only- the bitstream?
Postby shodruk » Thu Aug 14, 2014 3:37 pm
FHuettig wrote:Hi Shodruky, I thought the problem happened with the new SD image rather than the bitstream, so I was blaming software. :o Are you saying below that you can take the current OS image and get sound to work or fail by changing -only- the bitstream?
by changing only the bitstream.
I installed these files, HDMI sound didn't work.
Then I simply replaced the parallella.bit.bin with the file in the rel.14.02.06.tgz, it works normally.
I've tested these commands with both bit.bin files, the outputs are exactly the same.
cat /proc/asound/cards
cat /proc/asound/devices
cat /proc/asound/pcm
cat /proc/asound/timers
aplay -l
aplay -L
mplayer Videos/Big_Buck_Bunny_small.ogv
like below.
linaro-nano:~> cat /proc/asound/cards
 0 [monitor        ]: HDMI_monitor - HDMI monitor
                      HDMI monitor
linaro-nano:~> cat /proc/asound/devices
  0: [ 0]   : control
 16: [ 0- 0]: digital audio playback
 33:        : timer
linaro-nano:~> cat /proc/asound/pcm
00-00: HDMI adv7511-0 :  : playback 1
linaro-nano:~> cat /proc/asound/timers
G0: system timer : 10000.000us (10000000 ticks)
P0-0-0: PCM playback 0-0-0 : SLAVE
linaro-nano:~> aplay -l
**** List of PLAYBACK Hardware Devices ****
card 0: monitor [HDMI monitor], device 0: HDMI adv7511-0 []
  Subdevices: 1/1
  Subdevice #0: subdevice #0
linaro-nano:~> aplay -L
null
    Discard all samples (playback) or generate zero samples (capture)
pulse
    PulseAudio Sound Server
default
sysdefault:CARD=monitor
    HDMI monitor,
    Default Audio Device
dmix:CARD=monitor,DEV=0
    HDMI monitor,
    Direct sample mixing device
dsnoop:CARD=monitor,DEV=0
    HDMI monitor,
    Direct sample snooping device
hw:CARD=monitor,DEV=0
    HDMI monitor,
    Direct hardware device without any conversions
plughw:CARD=monitor,DEV=0
    HDMI monitor,
    Hardware device with all software conversions
linaro-nano:~> mplayer Videos/Big_Buck_Bunny_small.ogv
MPlayer2 2.0-701-gd4c5b7f-2ubuntu2 (C) 2000-2012 MPlayer Team
Cannot open file '/home/linaro/.mplayer/input.conf': No such file or directory
Failed to open /home/linaro/.mplayer/input.conf.
Cannot open file '/etc/mplayer/input.conf': No such file or directory
Failed to open /etc/mplayer/input.conf.
Playing Videos/Big_Buck_Bunny_small.ogv.
Detected file format: Ogg (libavformat)
[ogg @ 0xb61a1cc0]Multiple fisbone for the same stream is not implemented. Update your Libav version to the newest one from Git. If the problem still occurs, it means that your file has a feature which has not been implemented.
[ogg @ 0xb61a1cc0]29 bytes of comment header remain
[ogg @ 0xb61a1cc0]truncated comment header, 1 comments not found
[ogg @ 0xb61a1cc0]max_analyze_duration reached
[lavf] stream 1: video (theora), -vid 0
[lavf] stream 2: audio (vorbis), -aid 0
Load subtitles in Videos/
Failed to open VDPAU backend libvdpau_nvidia.so: cannot open shared object file: No such file or directory
[vdpau] Error when calling vdp_device_create_x11: 1
[VO_XV] It seems there is no Xvideo support for your video card available.
[VO_XV] Run 'xvinfo' to verify its Xv support and read
[VO_XV] DOCS/HTML/en/video.html#xv!
[VO_XV] See 'mplayer -vo help' for other (non-xv) video out drivers.
[VO_XV] Try -vo x11.
[ass] auto-open
Selected video codec: Theora [libavcodec]
Selected audio codec: Vorbis [libavcodec]
AUDIO: 48000 Hz, 2 ch, floatle, 48.0 kbit/1.56% (ratio: 6000->384000)
AO: [pulse] Init failed: Connection refused
[AO_ALSA] Format floatle is not supported by hardware, trying default.
AO: [alsa] 48000Hz 2ch s16le (2 bytes per sample)
[AO_ALSA] Unable to find simple control 'Master',0.
Starting playback...
VIDEO:  240x144  24.000 fps    0.0 kbps ( 0.0 kB/s)
VO: [x11] 240x144 => 240x144 Planar YV12
[swscaler @ 0xb60e3988]No accelerated colorspace conversion found from yuv420p to bgra.
[swscaler @ 0xb60e3988]using unscaled yuv420p -> bgra special converter
A:  -0.0 V:   0.0 A-V: -0.042 ct:  0.000   0/  0 ??% ??% ??,?% 0 0
* MPlayer outputs some errors, but these are normal.
Also dmesgs are almost the same except "auto-serial-console" lines.
linaro-nano:~> diff dmesg-oldbitbin.txt dmesg-newbitbin.txt
> init: failsafe main process (1466) killed by TERM signal
< init: auto-serial-console main process ended, respawning
< init: plymouth-stop pre-start process (2133) terminated with status 1
< init: auto-serial-console respawning too fast, stopped
The only difference is that MPlayer just freezes at start with the new bit.bin file. (can be stopped with ctrl-c)
I've tested with audio files instead of video files, the result is the same.
Postby PJoanes » Fri Aug 22, 2014 12:55 pm
Hi, I have exactly the same problem. I wish I hadn't spent so long investigating it before looking here!
Unfortunately I have the 7010 version so won't be able to have working audio without a new FPGA file release.
- Peter.
PJoanes
Postby frankje » Sat Sep 06, 2014 2:11 pm
I needed to install the 7010 version, but also I get no sound. is there maybe another updated 7010 file?
thnx, Frank
frankje
