Parallella Community • View topic - Only 2 out of 5 monitors work
Postby theller » Fri Nov 07, 2014 7:57 pm
I have tried 5 monitors and only 2 worked. I really need the other 3 to work. They are a Gateway fpd1765, Hp em869a, dell 1907fpt.
I am using an hdmi to dvi adaptor and my thought is if 2 work the problem is not in the adaptor or cables.
I just downloaded and made a new image and still they don't work. Here is the /var/log/Xorg.0.log while attached to the Hp:
[ 19.844]
X.Org X Server 1.15.1
Release Date: 2014-04-13
[ 19.844] X Protocol Version 11, Revision 0
[ 19.844] Build Operating System: Linux 3.2.0-58-highbank armv7l Ubuntu
[ 19.845] Current Operating System: Linux linaro-nano 3.12.0-g0bc9c3a-dirty #6 SMP PREEMPT Wed Jan 29 10:25:25 CET 2014 armv7l
[ 19.845] Kernel command line: root=/dev/mmcblk0p2 rw rootfstype=ext4
[ 19.845] Build Date: 16 April 2014 01:41:53PM
[ 19.845] xorg-server 2:1.15.1-0ubuntu2 (For technical support please see http://www.ubuntu.com/support)
[ 19.845] Current version of pixman: 0.30.2
[ 19.846] Before reporting problems, check http://wiki.x.org
to make sure that you have the latest version.
[ 19.846] Markers: (--) probed, (**) from config file, (==) default setting,
(++) from command line, (!!) notice, (II) informational,
(WW) warning, (EE) error, (NI) not implemented, (??) unknown.
[ 19.847] (==) Log file: "/var/log/Xorg.0.log", Time: Fri Nov 7 18:36:09 2014
[ 19.860] (==) Using config file: "/etc/X11/xorg.conf"
[ 19.861] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[ 19.897] (==) No Layout section. Using the first Screen section.
[ 19.897] (**) |-->Screen "Screen0" (0)
[ 19.898] (**) | |-->Monitor "<default monitor>"
[ 19.899] (**) | |-->Device "Card0"
[ 19.899] (==) No monitor specified for screen "Screen0".
Using a default monitor configuration.
[ 19.899] (==) Automatically adding devices
[ 19.899] (==) Automatically enabling devices
[ 19.902] (==) Automatically adding GPU devices
[ 19.938] (WW) The directory "/usr/share/fonts/X11/cyrillic" does not exist.
[ 19.938] Entry deleted from font path.
[ 19.938] (WW) The directory "/usr/share/fonts/X11/100dpi/" does not exist.
[ 19.938] (WW) The directory "/usr/share/fonts/X11/75dpi/" does not exist.
[ 19.939] Entry deleted from font path.
[ 19.940] (WW) The directory "/usr/share/fonts/X11/100dpi" does not exist.
[ 19.940] Entry deleted from font path.
[ 19.940] (WW) The directory "/usr/share/fonts/X11/75dpi" does not exist.
[ 19.941] (==) FontPath set to:
/usr/share/fonts/X11/misc,
/usr/share/fonts/X11/Type1,
built-ins
[ 19.941] (==) ModulePath set to "/usr/lib/arm-linux-gnueabihf/xorg/extra-modules,/usr/lib/xorg/extra-modules,/usr/lib/xorg/modules"
[ 19.941] (II) The server relies on udev to provide the list of input devices.
If no devices become available, reconfigure udev or disable AutoAddDevices.
[ 19.941] (II) Loader magic: 0xb6f9df18
[ 19.941] (II) Module ABI versions:
[ 19.941] X.Org ANSI C Emulation: 0.4
[ 19.941] X.Org Video Driver: 15.0
[ 19.941] X.Org XInput driver : 20.0
[ 19.941] X.Org Server Extension : 8.0
[ 19.944] (II) xfree86: Adding drm device (/dev/dri/card0)
[ 19.946] Initializing built-in extension Generic Event Extension
[ 19.946] Initializing built-in extension SHAPE
[ 19.947] Initializing built-in extension MIT-SHM
[ 19.947] Initializing built-in extension XInputExtension
[ 19.947] Initializing built-in extension XTEST
[ 19.947] Initializing built-in extension BIG-REQUESTS
[ 19.947] Initializing built-in extension SYNC
[ 19.947] Initializing built-in extension XKEYBOARD
[ 19.947] Initializing built-in extension XC-MISC
[ 19.948] Initializing built-in extension SECURITY
[ 19.948] Initializing built-in extension XINERAMA
[ 19.948] Initializing built-in extension XFIXES
[ 19.948] Initializing built-in extension RENDER
[ 19.948] Initializing built-in extension RANDR
[ 19.948] Initializing built-in extension COMPOSITE
[ 19.948] Initializing built-in extension DAMAGE
[ 19.949] Initializing built-in extension MIT-SCREEN-SAVER
[ 19.949] Initializing built-in extension DOUBLE-BUFFER
[ 19.949] Initializing built-in extension RECORD
[ 19.949] Initializing built-in extension DPMS
[ 19.949] Initializing built-in extension Present
[ 19.949] Initializing built-in extension DRI3
[ 19.949] Initializing built-in extension X-Resource
[ 19.953] Initializing built-in extension XVideo
[ 19.953] Initializing built-in extension XVideo-MotionCompensation
[ 19.953] Initializing built-in extension SELinux
[ 19.954] Initializing built-in extension XFree86-VidModeExtension
[ 19.954] Initializing built-in extension XFree86-DGA
[ 19.954] Initializing built-in extension XFree86-DRI
[ 19.954] Initializing built-in extension DRI2
[ 19.954] (II) LoadModule: "glx"
[ 19.967] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[ 20.106] (II) Module glx: vendor="X.Org Foundation"
[ 20.106] compiled for 1.15.1, module version = 1.0.0
[ 20.107] ABI class: X.Org Server Extension, version 8.0
[ 20.107] (==) AIGLX enabled
[ 20.107] Loading extension GLX
[ 20.107] (II) LoadModule: "modesetting"
[ 20.111] (II) Loading /usr/lib/xorg/modules/drivers/modesetting_drv.so
[ 20.133] (II) Module modesetting: vendor="X.Org Foundation"
[ 20.133] compiled for 1.15.0, module version = 0.8.1
[ 20.133] Module class: X.Org Video Driver
[ 20.133] ABI class: X.Org Video Driver, version 15.0
[ 20.134] (II) modesetting: Driver for Modesetting Kernel Drivers: kms
[ 20.134] (++) using VT number 7
[ 20.167] (II) modesetting(0): using drv /dev/dri/card0
[ 20.170] (==) modesetting(0): Depth 24, (==) framebuffer bpp 32
[ 20.170] (**) modesetting(0): Option "SWcursor" "True"
[ 20.171] (**) modesetting(0): Option "ShadowFB" "True"
[ 20.171] (==) modesetting(0): RGB weight 888
[ 20.171] (==) modesetting(0): Default visual is TrueColor
[ 20.171] (II) modesetting(0): ShadowFB: preferred NO, enabled YES
[ 20.174] (II) modesetting(0): Output HDMI-0 has no monitor section
[ 20.177] (II) modesetting(0): EDID for output HDMI-0
[ 20.177] (II) modesetting(0): Output HDMI-0 disconnected
[ 20.177] (WW) modesetting(0): No outputs definitely connected, trying again...
[ 20.178] (II) modesetting(0): Output HDMI-0 disconnected
[ 20.178] (WW) modesetting(0): Unable to find connected outputs - setting 1024x768 initial framebuffer
[ 20.178] (II) modesetting(0): Using default gamma of (1.0, 1.0, 1.0) unless otherwise stated.
[ 20.178] (==) modesetting(0): DPI set to (96, 96)
[ 20.178] (II) Loading sub module "fb"
[ 20.178] (II) LoadModule: "fb"
[ 20.187] (II) Loading /usr/lib/xorg/modules/libfb.so
[ 20.198] (II) Module fb: vendor="X.Org Foundation"
[ 20.198] compiled for 1.15.1, module version = 1.0.0
[ 20.198] ABI class: X.Org ANSI C Emulation, version 0.4
[ 20.199] (II) Loading sub module "shadow"
[ 20.199] (II) LoadModule: "shadow"
[ 20.202] (II) Loading /usr/lib/xorg/modules/libshadow.so
[ 20.207] (II) Module shadow: vendor="X.Org Foundation"
[ 20.208] compiled for 1.15.1, module version = 1.1.0
[ 20.208] ABI class: X.Org ANSI C Emulation, version 0.4
[ 20.208] (==) Depth 24 pixmap format is 32 bpp
[ 20.234] (==) modesetting(0): Backing store enabled
[ 20.234] (==) modesetting(0): Silken mouse enabled
[ 20.235] (II) modesetting(0): RandR 1.2 enabled, ignore the following RandR disabled message.
[ 20.236] (==) modesetting(0): DPMS enabled
[ 20.236] (WW) modesetting(0): Option "HWCursor" is not used
[ 20.237] (--) RandR disabled
[ 20.290] (II) SELinux: Disabled on system
[ 20.304] (II) AIGLX: Screen 0 is not DRI2 capable
[ 20.304] (EE) AIGLX: reverting to software rendering
[ 20.466] (II) AIGLX: Loaded and initialized swrast
[ 20.466] (II) GLX: Initialized DRISWRAST GL provider for screen 0
[ 20.470] (II) modesetting(0): Damage tracking initialized
[ 20.607] (II) XKB: reuse xkmfile /var/lib/xkb/server-B20D7FC79C7F597315E3E501AEF10E0D866E8E92.xkm
[ 20.656] (II) config/udev: Adding drm device (/dev/dri/card0)
[ 20.656] (II) config/udev: Ignoring already known drm device (/dev/dri/card0)
[ 20.743] (II) modesetting(0): Disabling kernel dirty updates, not required.
theller
Re: Only 2 out of 5 monitors work
Postby stingraze » Sun Nov 09, 2014 2:51 am
I guess that's how it is... compatibility issue. My LG HDMI monitor didn't work but my Sony Bravia TV with HDMI worked.
stingraze
Postby 9600 » Mon Nov 10, 2014 1:00 pm
I think it's more likely to be a matter of the monitor not supporting the default resolution, rather than a true compatibility issue.
I'd suggest checking what modes your monitor(s) support and then setting the resolution appropriately in the devicetree database and xorg configuration. See:
http://elinux.org/Parallella_Speed_Up_U ... o_1280x720
For the devicetree, you will need to decompile the stock one, make the edit and then recompile it.
viewtopic.php?f=48&t=1664
Postby theller » Tue Nov 11, 2014 5:40 pm
I have tried forcing the resolution according to the link you supplied. I set it to 1280x1024.
When I run this
xrandr -q
Screen 0: minimum 320 x 200, current 1280 x 1024, maximum 4096 x 4096
HDMI-0 connected 1280x1024+0+0 (normal left inverted right x axis y axis) 376mm x 301mm
1024x768 60.0
800x600 60.3 56.2
848x480 60.0
640x480 59.9
1280x1024 (0x42) 108.0MHz
h: width 1280 start 1328 end 1440 total 1688 skew 0 clock 64.0KHz
v: height 1024 start 1025 end 1028 total 1066 clock 60.0Hz
Is it odd that it is set to 108MHz?
theller
Postby theller » Tue Nov 11, 2014 6:35 pm
Here is something else I noticed:
the one monitor that works says on the back 50-60Hz 0.7A (I will check the other one when I get home)
The ones that don't work have 50-60Hz 1.0A, 1.5A & 1.3A
Could it be only monitors that require <1.0A work with the parallella?
theller
Postby 9600 » Tue Nov 11, 2014 8:12 pm
Not sure about your monitor/mode frequency. It's a while since I played around with xorg configuration, but it could be something in there. Hopefully someone else can comment.
The power ratings of the monitors will be a red herring — whatever current they draw from the mains certainly should not have a bearing on the Parallella.
Postby theller » Mon Nov 17, 2014 3:45 pm
Thank you Andrew. I did get the Gateway monitors to work but still no luck with 2 types of Hp monitors.
theller
