Fail to boot or get the ip address
Postby yunkpoon2 » Mon Nov 17, 2014 2:45 pm
Dear all, I am the newer of parallella board since I bought a P1600 last week. However, I am failed to access the board even I keep searching the cause online. At least, I would like to know if the SD card prepared well.
Here is the video I take to describe my situation. plz feel free to take a look and leave a comment.
https://www.youtube.com/watch?v=FrfxJwB ... freload=10
Thank you ^^
yunkpoon2
Re: Fail to boot or get the ip address
Postby gceline » Mon Nov 17, 2014 3:31 pm
Since you have the P1600, and the only port is the Ethernet, the only indication of booting is that the device requests and IP address. I assume you have tried the troubleshooting steps - viewtopic.php?f=50&t=1162
Some people have had issues with the BOOT partition files for headless operation - try Fred's new devicetree from here - viewtopic.php?f=50&t=1622&p=10037#p10037
Graham
Adapteva
gceline
Postby yunkpoon2 » Tue Nov 18, 2014 1:38 pm
Oh thanks. It is working right now. Here is another question I would like to ask. I know parallella has a coprocessor 'Epiphany'. Do I need to do sth special in order to execute my program on this coprocessor? I want to make parallella as a VPN server (using openssl and openvpn of course) which do serve 10 people. I want it run on this coprocessor. Thank you.
yunkpoon2
Postby gceline » Tue Nov 18, 2014 3:53 pm
Best place to look is in the examples folder of this forum, there you will find examples of code using the epiphany. The Epiphany coprocessor manual and SDK details are also available on the parallella.org website and github
Graham
Adapteva
gceline
Postby 9600 » Wed Nov 19, 2014 12:55 pm
yunkpoon2 wrote:I want to make parallella as a VPN server (using openssl and openvpn of course) which do serve 10 people. I want it run on this coprocessor. Thank you.
In which case you will need to extend/modify OpenSSL and OpenVPN. As Graham says, if you see the Epiphany and SDK documentation and examples, along with the numerous forum posts on writing programs that use the Epiphany.
