Zynq 7020 loaded, Epiphany doesnt work.
Postby korifey » Tue Jan 03, 2017 3:48 pm
Hello dear community. In December I ordered Parallella board (embedded with Zynq 7020) that I wanted for a long time to buy, but they were not available. Yesterday decided to start working with him. But I was very disappointed, because I can't run any one apps example on Epiphany.
I collected all logs, dmesg, output from the console. I tried to boot from different sd cards. And I use Image with supporting HDMi and without.
I will be very glad if you advise me what can be done. I'd really like to get my parallella worked.
Thank you.
console output
I2C:   ready
DRAM:  992 MiB
WARNING: Caches not enabled
MMC:   SDHCI: 0
In:    serial
Out:   serial
Err:   serial
Net:   zynq_gem
Hit any key to stop autoboot:  0
Device: SDHCI
Manufacturer ID: 2
OEM: 544d
Tran Speed: 50000000
Rd Block Len: 512
SD version 2.0
High Capacity: Yes
Capacity: 7.2 GiB
Bus Width: 4-bit
reading parallella.bit.bin
4045568 bytes read
reading uImage
4154824 bytes read
reading devicetree.dtb
13749 bytes read
   Image Name:   Linux-4.6.0+
   Image Type:   ARM Linux Kernel Image (uncompressed)
   Data Size:    4154760 Bytes = 4 MiB
   Load Address: 00008000
   Entry Point:  00008000
   Verifying Checksum ... OK
   Loading Kernel Image ... OK
OK
   Loading Device Tree to 1fff9000, end 1ffff5b4 ... OK
Starting kernel ...
Booting Linux on physical CPU 0x0
Linux version 4.6.0+ (esim@adapteva-dev) (gcc version 4.9.3 20141031 (prerelease) (Linaro GCC 2014.11) ) #1 SMP PREEMPT Wed Dec 7 13:27:40 CET 2016
CPU: ARMv7 Processor [413fc090] revision 0 (ARMv7), cr=18c5387d
CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
Machine model: Adapteva Parallella Board with headless bitstream
cma: Reserved 128 MiB at 0x36000000
Memory policy: Data cache writealloc
percpu: Embedded 12 pages/cpu @ef810000 s19392 r8192 d21568 u49152
Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 252416
Kernel command line: console=ttyPS0,115200 earlyprintk root=/dev/mmcblk0p2 rootfstype=ext4 rw rootwait
PID hash table entries: 4096 (order: 2, 16384 bytes)
Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
Memory: 867280K/1015808K available (5652K kernel code, 279K rwdata, 2132K rodata, 260K init, 159K bss, 17456K reserved, 131072K cma-reserved, 98304K highmem)
Virtual kernel memory layout:
    vector  : 0xffff0000 - 0xffff1000   (   4 kB)
    fixmap  : 0xffc00000 - 0xfff00000   (3072 kB)
    vmalloc : 0xf0800000 - 0xff800000   ( 240 MB)
    lowmem  : 0xc0000000 - 0xf0000000   ( 768 MB)
    pkmap   : 0xbfe00000 - 0xc0000000   (   2 MB)
    modules : 0xbf000000 - 0xbfe00000   (  14 MB)
      .text : 0xc0008000 - 0xc07a25f0   (7786 kB)
      .init : 0xc07a3000 - 0xc07e4000   ( 260 kB)
      .data : 0xc07e4000 - 0xc0829fa0   ( 280 kB)
       .bss : 0xc0829fa0 - 0xc0851c44   ( 160 kB)
Preemptible hierarchical RCU implementation.
   Build-time adjustment of leaf fanout to 32.
   RCU restricting CPUs from NR_CPUS=4 to nr_cpu_ids=2.
RCU: Adjusting geometry for rcu_fanout_leaf=32, nr_cpu_ids=2
NR_IRQS:16 nr_irqs:16 16
slcr mapped to f0800000
L2C: platform modifies aux control register: 0x72360000 -> 0x72760000
L2C: DT/platform modifies aux control register: 0x72360000 -> 0x72760000
L2C-310 erratum 769419 enabled
L2C-310 enabling early BRESP for Cortex-A9
L2C-310 full line of zeros enabled for Cortex-A9
L2C-310 ID prefetch enabled, offset 1 lines
L2C-310 dynamic clock gating enabled, standby mode enabled
L2C-310 cache controller enabled, 8 ways, 512 kB
L2C-310: CACHE_ID 0x410000c8, AUX_CTRL 0x76760001
zynq_clock_init: clkc starts at f0800100
Zynq clock init
clocksource: ttc_clocksource: mask: 0xffff max_cycles: 0xffff, max_idle_ns: 537538477 ns
sched_clock: 16 bits at 54kHz, resolution 18432ns, wraps every 603975816ns
timer #0 at f0808000, irq=16
Console: colour dummy device 80x30
Calibrating delay loop... 1332.01 BogoMIPS (lpj=6660096)
pid_max: default: 32768 minimum: 301
Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
CPU: Testing write buffer coherency: ok
CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
Setting up static identity map for 0x8280 - 0x82d8
CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
Brought up 2 CPUs
SMP: Total of 2 processors activated (2664.03 BogoMIPS).
CPU: All CPU(s) started in SVC mode.
devtmpfs: initialized
VFP support v0.3: implementor 41 architecture 3 part 30 variant 9 rev 4
clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
pinctrl core: initialized pinctrl subsystem
NET: Registered protocol family 16
DMA: preallocated 256 KiB pool for atomic coherent allocations
cpuidle: using governor ladder
zynq-gpio e000a000.gpio: could not find pctldev for node /amba/slcr@f8000000/pinctrl@700/gpio0-default, deferring probe
hw-breakpoint: found 5 (+1 reserved) breakpoint and 1 watchpoint registers.
hw-breakpoint: maximum watchpoint size is 4 bytes.
zynq-ocm f800c000.ocmc: ZYNQ OCM pool: 256 KiB @ 0xf0880000
zynq-pinctrl 700.pinctrl: zynq pinctrl initialized
SCSI subsystem initialized
usbcore: registered new interface driver usbfs
usbcore: registered new interface driver hub
usbcore: registered new device driver usb
media: Linux media interface: v0.10
Linux video capture interface: v2.00
pps_core: LinuxPPS API ver. 1 registered
pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
PTP clock support registered
EDAC MC: Ver: 3.0.0
Advanced Linux Sound Architecture Driver Initialized.
Bluetooth: Core ver 2.21
NET: Registered protocol family 31
Bluetooth: HCI device and connection manager initialized
Bluetooth: HCI socket layer initialized
Bluetooth: L2CAP socket layer initialized
Bluetooth: SCO socket layer initialized
clocksource: Switched to clocksource ttc_clocksource
NET: Registered protocol family 2
TCP established hash table entries: 8192 (order: 3, 32768 bytes)
TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
TCP: Hash tables configured (established 8192 bind 8192)
UDP hash table entries: 512 (order: 2, 16384 bytes)
UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
hw perfevents: enabled with armv7_cortex_a9 PMU driver, 7 counters available
futex hash table entries: 512 (order: 3, 32768 bytes)
workingset: timestamp_bits=28 max_order=18 bucket_order=0
fuse init (API version 7.24)
bounce: pool size: 64 pages
io scheduler noop registered
io scheduler deadline registered
io scheduler cfq registered (default)
Error: Driver 'mwipcore' is already registered, aborting...
dma-pl330 f8003000.dmac: Loaded driver for PL330 DMAC-241330
dma-pl330 f8003000.dmac:    DBUFF-128x8bytes Num_Chans-8 Num_Peri-4 Num_Events-16
e0001000.serial: ttyPS0 at MMIO 0xe0001000 (irq = 25, base_baud = 3125000) is a xuartps
console [ttyPS0] enabled
xdevcfg f8007000.devcfg: ioremap 0xf8007000 to f085e000
[drm] Initialized drm 1.1.0 20060810
brd: module loaded
loop: module loaded
zram: Added device: zram0
zynq-qspi e000d000.spi: couldn't determine configuration info about dual memories. defaulting to single memory
m25p80 spi32766.0: SPI-NOR-UniqueID 1000002333426206003600240710135e0d
m25p80 spi32766.0: n25q128a13 (16384 Kbytes)
3 ofpart partitions found on MTD device spi32766.0
Creating 3 MTD partitions on "spi32766.0":
0x000000000000-0x0000004e0000 : "boot"
0x0000004e0000-0x000000500000 : "bootenv"
0x000000ff0000-0x000001000000 : "version"
gpiod_set_value: invalid GPIO
libphy: MACB_mii_bus: probed
macb e000b000.ethernet eth0: Cadence GEM rev 0x00020118 at 0xe000b000 irq 27 (04:4f:8b:00:18:84)
Marvell 88E1318S e000b000.etherne:00: attached PHY driver [Marvell 88E1318S] (mii_bus:phy_addr=e000b000.etherne:00, irq=-1)
usbcore: registered new interface driver asix
usbcore: registered new interface driver ax88179_178a
usbcore: registered new interface driver cdc_ether
usbcore: registered new interface driver net1080
usbcore: registered new interface driver cdc_subset
usbcore: registered new interface driver zaurus
usbcore: registered new interface driver cdc_ncm
aoe: AoE v85 initialised.
ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
usbcore: registered new interface driver usb-storage
usbcore: registered new interface driver usbserial
usbcore: registered new interface driver usbserial_generic
usbserial: USB Serial support registered for generic
usbcore: registered new interface driver ftdi_sio
usbserial: USB Serial support registered for FTDI USB Serial Device
e0002000.usb supply vbus not found, using dummy regulator
ULPI transceiver vendor/product ID 0x0424/0x0007
Found SMSC USB3320 ULPI transceiver.
ULPI integrity check: passed.
ci_hdrc ci_hdrc.0: EHCI Host Controller
ci_hdrc ci_hdrc.0: new USB bus registered, assigned bus number 1
ci_hdrc ci_hdrc.0: USB 2.0 started, EHCI 1.00
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 1 port detected
e0003000.usb supply vbus not found, using dummy regulator
ci_hdrc ci_hdrc.1: unable to init phy: -110
ci_hdrc: probe of ci_hdrc.1 failed with error -110
mousedev: PS/2 mouse device common for all mice
i2c /dev entries driver
cdns-i2c e0004000.i2c: 100 kHz mmio e0004000 irq 22
Xilinx Zynq CpuIdle Driver started
sdhci: Secure Digital Host Controller Interface driver
sdhci: Copyright(c) Pierre Ossman
sdhci-pltfm: SDHCI platform and OF driver helper
mmc0: Invalid maximum block size, assuming 512 bytes
mmc0: SDHCI controller on e0101000.sdhci [e0101000.sdhci] using ADMA
ledtrig-cpu: registered to indicate activity on CPUs
hidraw: raw HID events driver (C) Jiri Kosina
usbcore: registered new interface driver usbhid
usbhid: USB HID core driver
usbcore: registered new interface driver snd-usb-audio
NET: Registered protocol family 10
sit: IPv6 over IPv4 tunneling driver
NET: Registered protocol family 17
bridge: automatic filtering via arp/ip/ip6tables has been deprecated. Update your scripts to load br_netfilter if you need this.
Bluetooth: RFCOMM TTY layer initialized
Bluetooth: RFCOMM socket layer initialized
Bluetooth: RFCOMM ver 1.11
Bluetooth: BNEP (Ethernet Emulation) ver 1.3
Bluetooth: BNEP filters: protocol multicast
Bluetooth: BNEP socket layer initialized
Bluetooth: HIDP (Human Interface Emulation) ver 1.2
Bluetooth: HIDP socket layer initialized
Registering SWP/SWPB emulation handler
hctosys: unable to open rtc device (rtc0)
mmc0: new high speed SDHC card at address 1234
VDD_DSP: disabling
ALSA device list:
  No soundcards found.
Waiting for root device /dev/mmcblk0p2...
mmcblk0: mmc0:1234 SA08G 7.21 GiB
 mmcblk0: p1 p2
devtmpfs: mounted
Freeing unused kernel memory: 260K (c07a3000 - c07e4000)
This architecture does not have kernel memory protection.
random: systemd urandom read with 6 bits of entropy available
[00]
Welcome to [1B][1mUbuntu 15.04[1B][0m!
Cannot add dependency job for unit display-manager.service, ignoring: Unit display-manager.service failed to load: No such file or directory.
[[1B][32m  OK  [1B][0m] Created slice Root Slice.
[[1B][32m  OK  [1B][0m] Listening on udev Kernel Socket.
[[1B][32m  OK  [1B][0m] Listening on Journal Socket (/dev/log).
[[1B][32m  OK  [1B][0m] Reached target Remote File Systems (Pre).
[[1B][32m  OK  [1B][0m] Listening on Delayed Shutdown Socket.
[[1B][32m  OK  [1B][0m] Created slice System Slice.
         Starting Increase datagram queue length...
[[1B][32m  OK  [1B][0m] Reached target Swap.
[[1B][32m  OK  [1B][0m] Listening on udev Control Socket.
[[1B][32m  OK  [1B][0m] Created slice system-serial\x2dgetty.slice.
[[1B][32m  OK  [1B][0m] Created slice User and Session Slice.
[[1B][32m  OK  [1B][0m] Reached target Slices.
[[1B][32m  OK  [1B][0m] Reached target Encrypted Volumes.
[[1B][32m  OK  [1B][0m] Listening on Journal Socket.
         Mounting Debug File System...
         Starting Setup Virtual Console...
         Starting Create list of required st... nodes for the current kernel...
         Starting Remount Root and Kernel File Systems...
         Starting Load Kernel Modules...
         Starting Restore / save the current clock...
         Starting udev Coldplug all Devices...
[[1B][32m  OK  [1B][0m] Listening on /dev/initctl Compatibility Named Pipe.
[[1B][32m  OK  [1B][0m] Created slice system-getty.slice.
[[1B][32m  OK  [1B][0m] Started Setup Virtual Console.
[[1B][32m  OK  [1B][0m] Started Create list of required sta...ce nodes for the current kernel.
[[1B][32m  OK  [1B][0m] Started Remount Root and Kernel File Systems.
[[1B][32m  OK  [1B][0m] Started Load Kernel Modules.
         Mounting FUSE Control File System...
         Starting Apply Kernel Variables...
         Starting Load/Save Random Seed...
         Starting Create Static Device Nodes in /dev...
[[1B][32m  OK  [1B][0m] Mounted Debug File System.
[[1B][32m  OK  [1B][0m] Mounted FUSE Control File System.
[[1B][32m  OK  [1B][0m] Started Increase datagram queue length.
[[1B][32m  OK  [1B][0m] Started Load/Save Random Seed.
[[1B][32m  OK  [1B][0m] Started Apply Kernel Variables.
[[1B][32m  OK  [1B][0m] Started Create Static Device Nodes in /dev.
[[1B][32m  OK  [1B][0m] Started Restore / save the current clock.
[[1B][32m  OK  [1B][0m] Started udev Coldplug all Devices.
         Starting udev Kernel Device Manager...
[[1B][32m  OK  [1B][0m] Reached target Local File Systems (Pre).
[[1B][32m  OK  [1B][0m] Reached target Local File Systems.
[[1B][32m  OK  [1B][0m] Reached target Remote File Systems.
         Starting Tell Plymouth To Write Out Runtime Data...
         Starting Wait for all "auto" /etc/n... up for network-online.target...
         Starting Set console keymap...
         Starting LSB: Raise network interfaces....
[[1B][32m  OK  [1B][0m] Listening on Syslog Socket.
         Starting Journal Service...
[[1B][32m  OK  [1B][0m] Started Tell Plymouth To Write Out Runtime Data.
[[1B][32m  OK  [1B][0m] Started udev Kernel Device Manager.
[[1B][32m  OK  [1B][0m] Reached target Paths.
         Starting Copy rules generated while the root was ro...
[[1B][32m  OK  [1B][0m] Started Journal Service.
         Starting Flush Journal to Persistent Storage...
[[1B][32m  OK  [1B][0m] Started Copy rules generated while the root was ro.
[[1B][32m  OK  [1B][0m] Started Set console keymap.
[[1B][32m  OK  [1B][0m] Started Flush Journal to Persistent Storage.
         Starting Create Volatile Files and Directories...
[[1B][32m  OK  [1B][0m] Started Create Volatile Files and Directories.
         Starting Update UTMP about System Boot/Shutdown...
[[1B][32m  OK  [1B][0m] Reached target System Time Synchronized.
[[1B][32m  OK  [1B][0m] Found device /dev/ttyPS0.
epiphany elink0: elink: unsupported platform: 0xef.
[00]¡•[0B]+¹‘±•‘ fault: imprecise external abort (0x1406) at 0xb6b7d6b0
pgd = ee4e0000
[b6b7d6b0] *pgd=2e57e831, *pte=2d47a79f, *ppte=2d47ae7f
[00][[1B][32m  OK  [1B][0m] Started Update UTMP about System Boot/Shutdown.
epiphany elink0: probing failed
elink 81000000.elink0: failed to register elink: -22
[[1B][32m  OK  [1B][0m] Created slice system-ifup.slice.
[[1B][32m  OK  [1B][0m] Started ifup for eth0.
         Starting ifup for eth0...
[[1B][32m  OK  [1B][0m] Started ifup for sit0.
         Starting ifup for sit0...
[[1B][0m[1B][31m*     [1B][0m] (1 of 2) A start job is running for...work interfaces. (7s / no limit)
[1B][K[[1B][1;31m*[1B][0m[1B][31m*    [1B][0m] (1 of 2) A start job is running for...work interfaces. (7s / no limit)
[1B][K[[1B][31m*[1B][1;31m*[1B][0m[1B][31m*   [1B][0m] (1 of 2) A start job is running for...work interfaces. (8s / no limit)
[1B][K[ [1B][31m*[1B][1;31m*[1B][0m[1B][31m*  [1B][0m] (2 of 2) A start job is running for...etwork-online.target (9s / 2min)
[1B][K[   [1B][31m*[1B][1;31m*[1B][0m[1B][31m*[1B][0m] (2 of 2) A start job is running for...twork-online.target (10s / 2min)
[1B][K[    [1B][31m*[1B][1;31m*[1B][0m] (1 of 2) A start job is running for...ork interfaces. (10s / no limit)
[1B][K[     [1B][31m*[1B][0m] (1 of 2) A start job is running for...ork interfaces. (11s / no limit)
[1B][K[    [1B][31m*[1B][1;31m*[1B][0m] (1 of 2) A start job is running for...ork interfaces. (11s / no limit)
[1B][K[   [1B][31m*[1B][1;31m*[1B][0m[1B][31m*[1B][0m] (2 of 2) A start job is running for...twork-online.target (12s / 2min)
[1B][K[[1B][32m  OK  [1B][0m] Started Wait for all "auto" /etc/ne...be up for network-online.target.
[[1B][32m  OK  [1B][0m] Stopped LSB: Start NTP daemon.
[[1B][32m  OK  [1B][0m] Started LSB: Raise network interfaces..
[[1B][32m  OK  [1B][0m] Reached target Network.
[[1B][32m  OK  [1B][0m] Reached target Network is Online.
[[1B][32m  OK  [1B][0m] Reached target System Initialization.
[[1B][32m  OK  [1B][0m] Listening on Avahi mDNS/DNS-SD Stack Activation Socket.
[[1B][32m  OK  [1B][0m] Listening on D-Bus System Message Bus Socket.
[[1B][32m  OK  [1B][0m] Reached target Sockets.
[[1B][32m  OK  [1B][0m] Reached target Basic System.
[[1B][32m  OK  [1B][0m] Started "Parallella Thermal Watchdog".
         Starting "Parallella Thermal Watchdog"...
         Starting Permit User Sessions...
         Starting LSB: Set the CPU Frequency Scaling governor to "ondemand"...
         Starting Initialize hardware monitoring sensors...
         Starting Login Service...
         Starting Avahi mDNS/DNS-SD Stack...
         Starting /etc/rc.local Compatibility...
[[1B][32m  OK  [1B][0m] Started OpenBSD Secure Shell server.
         Starting OpenBSD Secure Shell server...
         Starting System Logging Service...
         Starting D-Bus System Message Bus...
[[1B][32m  OK  [1B][0m] Started Deferred execution scheduler.
         Starting Deferred execution scheduler...
         Starting LSB: Brings up/down network automatically...
[[1B][32m  OK  [1B][0m] Started Regular background program processing daemon.
         Starting Regular background program processing daemon...
[[1B][32m  OK  [1B][0m] Reached target Timers.
[[1B][32m  OK  [1B][0m] Started Permit User Sessions.
[[1B][32m  OK  [1B][0m] Started LSB: Set the CPU Frequency Scaling governor to "ondemand".
[[1B][32m  OK  [1B][0m] Started /etc/rc.local Compatibility.
[[1B][32m  OK  [1B][0m] Started D-Bus System Message Bus.
[[1B][32m  OK  [1B][0m] Started Avahi mDNS/DNS-SD Stack.
[[1B][32m  OK  [1B][0m] Started LSB: Brings up/down network automatically.
[[1B][32m  OK  [1B][0m] Started Initialize hardware monitoring sensors.
[[1B][32m  OK  [1B][0m] Started System Logging Service.
         Starting Wait for Plymouth Boot Screen to Quit...
         Starting Terminate Plymouth Boot Screen...
[[1B][32m  OK  [1B][0m] Started Wait for Plymouth Boot Screen to Quit.
[[1B][32m  OK  [1B][0m] Started Terminate Plymouth Boot Screen.
[[1B][32m  OK  [1B][0m] Started Login Service.
[[1B][32m  OK  [1B][0m] Started Serial Getty on ttyPS0.
         Starting Serial Getty on ttyPS0...
[[1B][32m  OK  [1B][0m] Started Getty on tty1.
         Starting Getty on tty1...
[[1B][32m  OK  [1B][0m] Reached target Login Prompts.
[[1B][32m  OK  [1B][0m] Reached target Multi-User System.
[[1B][32m  OK  [1B][0m] Reached target Graphical Interface.
         Starting Update UTMP about System Runlevel Changes...
[[1B][32m  OK  [1B][0m] Started Update UTMP about System Runlevel Changes.
Ubuntu 15.04 parallella ttyPS0
parallella login: root (automatic login)
Last login: Tue Jan  3 01:57:31 UTC 2017 on ttyPS0
root@parallella:~#
dmesg
parallella@parallella:~$ dmesg
[    0.000000] Booting Linux on physical CPU 0x0
[    0.000000] Linux version 4.6.0+ (esim@adapteva-dev) (gcc version 4.9.3 20141031 (prerelease) (Linaro GCC 2014.11) ) #1 SMP PREEMPT Wed Dec 7 13:27:40 CET 2016
[    0.000000] CPU: ARMv7 Processor [413fc090] revision 0 (ARMv7), cr=18c5387d
[    0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[    0.000000] Machine model: Adapteva Parallella Board with headless bitstream
[    0.000000] cma: Reserved 128 MiB at 0x36000000
[    0.000000] Memory policy: Data cache writealloc
[    0.000000] On node 0 totalpages: 253952
[    0.000000] free_area_init_node: node 0, pgdat c0829000, node_mem_map ef838000
[    0.000000]   Normal zone: 1536 pages used for memmap
[    0.000000]   Normal zone: 0 pages reserved
[    0.000000]   Normal zone: 196608 pages, LIFO batch:31
[    0.000000]   HighMem zone: 57344 pages, LIFO batch:15
[    0.000000] percpu: Embedded 12 pages/cpu @ef810000 s19392 r8192 d21568 u49152
[    0.000000] pcpu-alloc: s19392 r8192 d21568 u49152 alloc=12*4096
[    0.000000] pcpu-alloc: [0] 0 [0] 1
[    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 252416
[    0.000000] Kernel command line: console=ttyPS0,115200 earlyprintk root=/dev/mmcblk0p2 rootfstype=ext4 rw rootwait
[    0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
[    0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
[    0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[    0.000000] Memory: 867280K/1015808K available (5652K kernel code, 279K rwdata, 2132K rodata, 260K init, 159K bss, 17456K reserved, 131072K cma-reserved, 98304K highmem)
[    0.000000] Virtual kernel memory layout:
[    0.000000] Preemptible hierarchical RCU implementation.
[    0.000000]    Build-time adjustment of leaf fanout to 32.
[    0.000000]    RCU restricting CPUs from NR_CPUS=4 to nr_cpu_ids=2.
[    0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=32, nr_cpu_ids=2
[    0.000000] NR_IRQS:16 nr_irqs:16 16
[    0.000000] slcr mapped to f0800000
[    0.000000] L2C: platform modifies aux control register: 0x72360000 -> 0x72760000
[    0.000000] L2C: DT/platform modifies aux control register: 0x72360000 -> 0x72760000
[    0.000000] L2C-310 erratum 769419 enabled
[    0.000000] L2C-310 enabling early BRESP for Cortex-A9
[    0.000000] L2C-310 full line of zeros enabled for Cortex-A9
[    0.000000] L2C-310 ID prefetch enabled, offset 1 lines
[    0.000000] L2C-310 dynamic clock gating enabled, standby mode enabled
[    0.000000] L2C-310 cache controller enabled, 8 ways, 512 kB
[    0.000000] L2C-310: CACHE_ID 0x410000c8, AUX_CTRL 0x76760001
[    0.000000] zynq_clock_init: clkc starts at f0800100
[    0.000000] Zynq clock init
[    0.000000] clocksource: ttc_clocksource: mask: 0xffff max_cycles: 0xffff, max_idle_ns: 537538477 ns
[    0.000018] sched_clock: 16 bits at 54kHz, resolution 18432ns, wraps every 603975816ns
[    0.000055] timer #0 at f0808000, irq=16
[    0.000387] Console: colour dummy device 80x30
[    0.000405] Calibrating delay loop... 1332.01 BogoMIPS (lpj=6660096)
[    0.090188] pid_max: default: 32768 minimum: 301
[    0.090336] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
[    0.090354] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
[    0.090999] CPU: Testing write buffer coherency: ok
[    0.091220] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[    0.091294] Setting up static identity map for 0x8280 - 0x82d8
[    0.280187] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
[    0.280297] Brought up 2 CPUs
[    0.280297] SMP: Total of 2 processors activated (2664.03 BogoMIPS).
[    0.280316] CPU: All CPU(s) started in SVC mode.
[    0.281366] devtmpfs: initialized
[    0.285311] VFP support v0.3: implementor 41 architecture 3 part 30 variant 9 rev 4
[    0.285698] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[    0.293679] pinctrl core: initialized pinctrl subsystem
[    0.295154] NET: Registered protocol family 16
[    0.297144] DMA: preallocated 256 KiB pool for atomic coherent allocations
[    0.320664] cpuidle: using governor ladder
[    0.322120] zynq-gpio e000a000.gpio: could not find pctldev for node /amba/slcr@f8000000/pinctrl@700/gpio0-default, deferring probe
[    0.327521] hw-breakpoint: found 5 (+1 reserved) breakpoint and 1 watchpoint registers.
[    0.327539] hw-breakpoint: maximum watchpoint size is 4 bytes.
[    0.327686] zynq-ocm f800c000.ocmc: ZYNQ OCM pool: 256 KiB @ 0xf0880000
[    0.328110] zynq-pinctrl 700.pinctrl: zynq pinctrl initialized
[    0.362689] SCSI subsystem initialized
[    0.363076] usbcore: registered new interface driver usbfs
[    0.363150] usbcore: registered new interface driver hub
[    0.363242] usbcore: registered new device driver usb
[    0.363666] media: Linux media interface: v0.10
[    0.363740] Linux video capture interface: v2.00
[    0.363813] pps_core: LinuxPPS API ver. 1 registered
[    0.363813] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    0.363850] PTP clock support registered
[    0.363943] EDAC MC: Ver: 3.0.0
[    0.371149] Advanced Linux Sound Architecture Driver Initialized.
[    0.371942] Bluetooth: Core ver 2.21
[    0.371997] NET: Registered protocol family 31
[    0.371997] Bluetooth: HCI device and connection manager initialized
[    0.372016] Bluetooth: HCI socket layer initialized
[    0.372034] Bluetooth: L2CAP socket layer initialized
[    0.372071] Bluetooth: SCO socket layer initialized
[    0.380513] clocksource: Switched to clocksource ttc_clocksource
[    0.392715] NET: Registered protocol family 2
[    0.393563] TCP established hash table entries: 8192 (order: 3, 32768 bytes)
[    0.393674] TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
[    0.393839] TCP: Hash tables configured (established 8192 bind 8192)
[    0.393895] UDP hash table entries: 512 (order: 2, 16384 bytes)
[    0.393950] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[    0.394227] NET: Registered protocol family 1
[    0.394853] hw perfevents: enabled with armv7_cortex_a9 PMU driver, 7 counters available
[    0.396236] futex hash table entries: 512 (order: 3, 32768 bytes)
[    0.397157] workingset: timestamp_bits=28 max_order=18 bucket_order=0
[    0.398005] fuse init (API version 7.24)
[    0.399461] bounce: pool size: 64 pages
[    0.399480] io scheduler noop registered
[    0.399498] io scheduler deadline registered
[    0.399535] io scheduler cfq registered (default)
[    0.399719] Error: Driver 'mwipcore' is already registered, aborting...
[    0.401286] dma-pl330 f8003000.dmac: Loaded driver for PL330 DMAC-241330
[    0.401286] dma-pl330 f8003000.dmac:    DBUFF-128x8bytes Num_Chans-8 Num_Peri-4 Num_Events-16
[    0.402171] e0001000.serial: ttyPS0 at MMIO 0xe0001000 (irq = 25, base_baud = 3125000) is a xuartps
[    0.895452] console [ttyPS0] enabled
[    0.898346] xdevcfg f8007000.devcfg: ioremap 0xf8007000 to f085e000
[    0.903802] [drm] Initialized drm 1.1.0 20060810
[    0.918603] brd: module loaded
[    0.937072] loop: module loaded
[    0.939653] zram: Added device: zram0
[    0.944058] zynq-qspi e000d000.spi: couldn't determine configuration info about dual memories. defaulting to single memory
[    0.954896] m25p80 spi32766.0: SPI-NOR-UniqueID 1000002333426206003600240710135e0d
[    0.962748] m25p80 spi32766.0: n25q128a13 (16384 Kbytes)
[    0.966693] 3 ofpart partitions found on MTD device spi32766.0
[    0.971208] Creating 3 MTD partitions on "spi32766.0":
[    0.975005] 0x000000000000-0x0000004e0000 : "boot"
[    0.979743] 0x0000004e0000-0x000000500000 : "bootenv"
[    0.984572] 0x000000ff0000-0x000001000000 : "version"
[    0.990949] gpiod_set_value: invalid GPIO
[    0.994728] libphy: MACB_mii_bus: probed
[    1.080806] macb e000b000.ethernet eth0: Cadence GEM rev 0x00020118 at 0xe000b000 irq 27 (04:4f:8b:00:18:84)
[    1.089248] Marvell 88E1318S e000b000.etherne:00: attached PHY driver [Marvell 88E1318S] (mii_bus:phy_addr=e000b000.etherne:00, irq=-1)
[    1.100602] usbcore: registered new interface driver asix
[    1.104694] usbcore: registered new interface driver ax88179_178a
[    1.109468] usbcore: registered new interface driver cdc_ether
[    1.114002] usbcore: registered new interface driver net1080
[    1.118352] usbcore: registered new interface driver cdc_subset
[    1.122979] usbcore: registered new interface driver zaurus
[    1.127255] usbcore: registered new interface driver cdc_ncm
[    1.132600] aoe: AoE v85 initialised.
[    1.134904] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    1.140176] usbcore: registered new interface driver usb-storage
[    1.145024] usbcore: registered new interface driver usbserial
[    1.149521] usbcore: registered new interface driver usbserial_generic
[    1.154756] usbserial: USB Serial support registered for generic
[    1.159438] usbcore: registered new interface driver ftdi_sio
[    1.163880] usbserial: USB Serial support registered for FTDI USB Serial Device
[    1.170331] e0002000.usb supply vbus not found, using dummy regulator
[    1.175713] ULPI transceiver vendor/product ID 0x0424/0x0007
[    1.179990] Found SMSC USB3320 ULPI transceiver.
[    1.183363] ULPI integrity check: passed.
[    1.185998] ci_hdrc ci_hdrc.0: EHCI Host Controller
[    1.189556] ci_hdrc ci_hdrc.0: new USB bus registered, assigned bus number 1
[    1.210550] ci_hdrc ci_hdrc.0: USB 2.0 started, EHCI 1.00
[    1.215416] hub 1-0:1.0: USB hub found
[    1.217812] hub 1-0:1.0: 1 port detected
[    1.221314] e0003000.usb supply vbus not found, using dummy regulator
[    1.229167] ci_hdrc ci_hdrc.1: unable to init phy: -110
[    1.233056] ci_hdrc: probe of ci_hdrc.1 failed with error -110
[    1.238788] mousedev: PS/2 mouse device common for all mice
[    1.253479] i2c /dev entries driver
[    1.259672] cdns-i2c e0004000.i2c: 100 kHz mmio e0004000 irq 22
[    1.266602] Xilinx Zynq CpuIdle Driver started
[    1.270031] sdhci: Secure Digital Host Controller Interface driver
[    1.274860] sdhci: Copyright(c) Pierre Ossman
[    1.277864] sdhci-pltfm: SDHCI platform and OF driver helper
[    1.282730] mmc0: Invalid maximum block size, assuming 512 bytes
[    1.320608] mmc0: SDHCI controller on e0101000.sdhci [e0101000.sdhci] using ADMA
[    1.327060] ledtrig-cpu: registered to indicate activity on CPUs
[    1.332903] hidraw: raw HID events driver (C) Jiri Kosina
[    1.344865] usbcore: registered new interface driver usbhid
[    1.349086] usbhid: USB HID core driver
[    1.364569] usbcore: registered new interface driver snd-usb-audio
[    1.371444] NET: Registered protocol family 10
[    1.375702] sit: IPv6 over IPv4 tunneling driver
[    1.379886] NET: Registered protocol family 17
[    1.383296] bridge: automatic filtering via arp/ip/ip6tables has been deprecated. Update your scripts to load br_netfilter if you need this.
[    1.394761] Bluetooth: RFCOMM TTY layer initialized
[    1.398282] Bluetooth: RFCOMM socket layer initialized
[    1.402171] Bluetooth: RFCOMM ver 1.11
[    1.404604] mmc0: new high speed SDHC card at address 1234
[    1.409046] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[    1.413009] Bluetooth: BNEP filters: protocol multicast
[    1.416880] Bluetooth: BNEP socket layer initialized
[    1.420585] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[    1.420677] mmcblk0: mmc0:1234 SA08G 7.21 GiB
[    1.428326] Bluetooth: HIDP socket layer initialized
[    1.428381]  mmcblk0: p1 p2
[    1.433727] Registering SWP/SWPB emulation handler
[    1.440712] hctosys: unable to open rtc device (rtc0)
[    1.448767] VDD_DSP: disabling
[    1.450905] ALSA device list:
[    1.452472]   No soundcards found.
[    1.476065] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[    1.482848] VFS: Mounted root (ext4 filesystem) on device 179:2.
[    1.498903] devtmpfs: mounted
[    1.500838] Freeing unused kernel memory: 260K (c07a3000 - c07e4000)
[    1.505796] This architecture does not have kernel memory protection.
[    1.790573] random: systemd urandom read with 57 bits of entropy available
[    2.164986] random: nonblocking pool is initialized
[    3.246419] systemd-journald[1494]: Received request to flush runtime journal from PID 1
[    3.838515] Unhandled fault: imprecise external abort (0x1406) at 0xb6e7fef2
[    3.844192] pgd = eeb28000
[    3.845575] [b6e7fef2] *pgd=2e411831, *pte=009c159f, *ppte=009c1e7e
[    3.850533] Internal error: : 1406 [#1] PREEMPT SMP ARM
[    3.854459] Modules linked in: epiphany(+)
[    3.857242] CPU: 0 PID: 1534 Comm: systemd-udevd Not tainted 4.6.0+ #1
[    3.862459] Hardware name: Xilinx Zynq Platform
[    3.865684] task: ee468d00 ti: ee916000 task.ti: ee916000
[    3.869813] PC is at elink_platform_probe+0x840/0xa1c [epiphany]
[    3.874513] LR is at arm_heavy_mb+0x18/0x38
[    3.877389] pc : [<bf002950>]    lr : [<c001a994>]    psr: 800c0013
sp : ee917cd8  ip : 0000064c  fp : ee8e81cc
[    3.886236] r10: ee8e81b0  r9 : ee8e8018  r8 : 00000000
[    3.890144] r7 : bf003f00  r6 : ef14c800  r5 : ef14c810  r4 : ee8e8010
[    3.895360] r3 : deadbeef  r2 : 000003e0  r1 : ef810c00  r0 : 00000000
[    3.900558] Flags: Nzcv  IRQs on  FIQs on  Mode SVC_32  ISA ARM  Segment none
[    3.906383] Control: 18c5387d  Table: 2eb2804a  DAC: 00000051
[    3.910825] Process systemd-udevd (pid: 1534, stack limit = 0xee916210)
[    3.916133] Stack: (0xee917cd8 to 0xee918000)
[    3.919156] 7cc0:                                                       ef105540 ef105540
[    3.926031] 7ce0: ee8e8010 c01ccb74 0f300000 0000000c 00000000 8e000000 3e000000 02000000
[    3.932906] 7d00: 80000000 8fffffff ef834b18 00000200 00000000 00000000 00000000 00000000
[    3.939763] 7d20: 00000000 3fffffff ef834448 00000200 00000000 00000000 00000000 00000000
[    3.946638] 7d40: 00000001 bf002110 ef14c810 bf003c1c bf003c1c c0845344 00000004 eeb63164
[    3.953514] 7d60: eeb63148 c026a1cc ef14c810 c084533c 00000000 c0268a2c ef14c810 ef14c844
[    3.960389] 7d80: bf003c1c c07fa6c8 bf003f00 00000001 eeb63164 c0268c14 00000000 bf003c1c
[    3.967264] 7da0: c0268b94 c0267164 ef00f75c ef14abb4 bf003c1c 00000000 ef30a900 c02680f4
[    3.974139] 7dc0: bf003b7c bf003b7d 00000000 bf003c1c 00000000 bf003d00 bf003ac5 c0269418
[    3.980996] 7de0: 00000000 00000000 bf003d00 bf0060ec ee903580 bf006000 c07e9a10 c07e9a10
[    3.987871] 7e00: 00000000 c0009704 00000001 efe0d320 00000000 00000001 c06de153 c009b2bc
[    3.994728] 7e20: c07e98c4 efe0d300 00000000 ef838000 00000001 eeb63140 00000000 00000000
[    4.001603] 7e40: eeb63148 c009d194 00000000 00000039 f09a8000 eeb63380 bf003d00 ee917f54
[    4.008460] 7e60: eeb63380 bf003d48 eeb63140 c00955d0 bf003d00 0002eb63 bf003d00 ee917f54
[    4.015335] 7e80: 00000001 c007d9d0 bf003d0c 00007fff bf003d00 c007b0cc 00000000 c007aff4
[    4.022192] 7ea0: bf003eb4 0000013d 00000000 f09d0a3c b6d7b574 00038219 00000000 c00d86f0
[    4.029049] 7ec0: 00038219 00000000 7fffffff 00000000 00000000 00000000 00000000 00000000
[    4.035924] 7ee0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[    4.042799] 7f00: 00000000 00000000 7fffffff 00000000 b6d7b574 00000008 0000017b c000efc4
[    4.049656] 7f20: ee916000 00000000 7f5eb168 c007e028 7fffffff 00000000 00000002 ef08d1e0
[    4.056531] 7f40: ef08d1e0 f09a8000 00038219 00000000 00000000 f09a8000 00038219 f09d0294
[    4.063425] 7f60: f09d00a7 f09df55c 00003fb0 000046b0 00000000 00000000 00000000 00002200
[    4.070300] 7f80: 00000031 00000032 0000001b 00000018 00000014 00000000 7f5eb168 7f5ec8f0
[    4.077175] 7fa0: 077dc500 c000ee00 7f5eb168 7f5ec8f0 00000008 b6d7b574 00000000 00000000
[    4.084032] 7fc0: 7f5eb168 7f5ec8f0 077dc500 0000017b 00020000 7f5d2b18 00000000 7f5eb168
[    4.090907] 7fe0: bed02ec0 bed02eb0 b6d75987 b6e7e622 80070030 00000008 2fffd861 2fffdc61
[    4.097819] [<bf002950>] (elink_platform_probe [epiphany]) from [<c026a1cc>] (platform_drv_probe+0x50/0xa0)
[    4.106261] [<c026a1cc>] (platform_drv_probe) from [<c0268a2c>] (driver_probe_device+0x134/0x29c)
[    4.113837] [<c0268a2c>] (driver_probe_device) from [<c0268c14>] (__driver_attach+0x80/0xa4)
[    4.120970] [<c0268c14>] (__driver_attach) from [<c0267164>] (bus_for_each_dev+0x68/0x8c)
[    4.127827] [<c0267164>] (bus_for_each_dev) from [<c02680f4>] (bus_add_driver+0xc8/0x1e4)
[    4.134702] [<c02680f4>] (bus_add_driver) from [<c0269418>] (driver_register+0x9c/0xe0)
[    4.141411] [<c0269418>] (driver_register) from [<bf0060ec>] (epiphany_module_init+0xec/0x170 [epiphany])
[    4.149687] [<bf0060ec>] (epiphany_module_init [epiphany]) from [<c0009704>] (do_one_initcall+0x104/0x1b8)
[    4.158037] [<c0009704>] (do_one_initcall) from [<c00955d0>] (do_init_module+0x54/0x1ac)
[    4.164820] [<c00955d0>] (do_init_module) from [<c007d9d0>] (load_module+0x1748/0x1be4)
[    4.171529] [<c007d9d0>] (load_module) from [<c007e028>] (SyS_finit_module+0x88/0x90)
[    4.178054] [<c007e028>] (SyS_finit_module) from [<c000ee00>] (ret_fast_syscall+0x0/0x3c)
[    4.184911] Code: e5943180 e283380f e593320c f57ff04f (e3530000)
[    4.189703] ---[ end trace 74f91c8bcde4e277 ]---
[    4.966103] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[    8.200910] macb e000b000.ethernet eth0: link up (100/Full)
[    8.205113] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
test.sh
parallella@parallella:~/tests/epiphany-sdk$ ./test.sh
Cloning into 'epiphany-examples'...
remote: Counting objects: 4095, done.
remote: Total 4095 (delta 0), reused 0 (delta 0), pack-reused 4095
Receiving objects: 100% (4095/4095), 1.04 MiB | 687.00 KiB/s, done.
Resolving deltas: 100% (2216/2216), done.
Checking connectivity... done.
Phase 1: Build and run all tests once
Directory                           Build       Test
apps/dotproduct                     OK          EXIT_FAIL
apps/e-bandwidth-test               OK          EXIT_FAIL
apps/e-dump-mem                     OK          EXIT_FAIL
apps/e-dump-regs                    OK          SKIP
apps/e-fill-mem                     OK          EXIT_FAIL
apps/e-mem-sync                     OK          EXIT_FAIL
apps/e-toggle-led                   OK          N/A
apps/eprime                         OK          SKIP
apps/erm                            OK          SKIP
apps/erm_example                    OK          SKIP
apps/fft2d                          OK          EXIT_FAIL
apps/hello-world                    OK          EXIT_FAIL
apps/matmul-16                      OK          EXIT_FAIL
apps/matmul-64                      OK          SKIP
apps/shm_test                       OK          EXIT_FAIL
archive/e-init                      SKIP        SKIP
archive/e-standby-test              SKIP        SKIP
archive/e-test                      SKIP        SKIP
cpu/arithmode                       OK          EXIT_FAIL
cpu/assembly                        OK          EXIT_FAIL
cpu/basic_math                      OK          EXIT_FAIL
cpu/complex_numbers                 OK          EXIT_OK
cpu/ctimer                          OK          SKIP
cpu/interrupt-demo                  OK          EXIT_FAIL
cpu/interrupts                      OK          EXIT_FAIL
cpu/mutex                           OK          EXIT_FAIL
cpu/nested_interrupts               OK          EXIT_FAIL
cpu/register_test                   OK          EXIT_FAIL
cpu/remote_call                     OK          EXIT_FAIL
dma/dma_2d                          OK          EXIT_FAIL
dma/dma_chain                       OK          EXIT_FAIL
dma/dma_interrupt                   OK          EXIT_FAIL
dma/dma_message_read                OK          EXIT_FAIL
dma/dma_message_write               OK          EXIT_FAIL
dma/dma_slave                       OK          EXIT_FAIL
emesh/emesh_bandwidth_all2one       OK          EXIT_FAIL
emesh/emesh_bandwidth_bisection     OK          EXIT_FAIL
emesh/emesh_bandwidth_neighbour     OK          EXIT_FAIL
emesh/emesh_read_latency            OK          EXIT_FAIL
emesh/emesh_traffic                 OK          EXIT_FAIL
errata/noc_fifo                     OK          EXIT_FAIL
io/link_lowpower_mode               OK          SKIP
labs/clockgating_mode               OK          SKIP
labs/hardware_barrier               OK          SKIP
labs/hardware_loops                 OK          SKIP
labs/mailbox-test                   OK          SKIP
labs/mem_protect                    OK          SKIP
softcache/basic_math                OK          EXIT_FAIL
softcache/math_example              OK          EXIT_FAIL
test/e-extmem-test                  OK          N/A
test/e-free-resource-leak-test      OK          EXIT_FAIL
test/e-loopback-test                OK          SKIP
test/e-matmul-test                  SKIP        SKIP
test/e-mem-test                     OK          EXIT_FAIL
test/e-mesh-test                    OK          EXIT_FAIL
test/e-read-buf                     OK          EXIT_FAIL
test/e-read-word                    OK          EXIT_FAIL
test/e-regfile-test                 OK          EXIT_FAIL
test/e-reset                        OK          EXIT_OK
test/e-test                         SKIP        SKIP
test/e-write-buf                    OK          EXIT_FAIL
test/e-write-word                   OK          EXIT_FAIL
test/test-elink-rx-remapping        OK          EXIT_FAIL
test/test-linker-script-symbols     OK          EXIT_FAIL
test/test-load-elf-w-empty-segment  OK          EXIT_FAIL
Phase 2: Select repeated tests
Directory                           Test        Iterations
apps/e-bandwidth-test (100 iterations)
                                        FAIL        1
apps/matmul-16 (100 iterations)
                                        FAIL        1
dma/dma_slave (100 iterations)
                                        FAIL        1
test/e-mem-test (10 iterations)
                                        FAIL        1
STATUS: FAIL
FAIL
SN 006276
korifey
Re: Zynq 7020 loaded, Epiphany doesnt work.
Postby aolofsson » Tue Jan 03, 2017 6:49 pm
Sorry to hear that. Please specify EXACT path to binary downloaded and we will verify on our end as well.
Postby korifey » Tue Jan 03, 2017 7:10 pm
Hello Andreas,
i tried each of this
1. with HDMI support https://github.com/parallella/parabuntu/releases/download/parabuntu-2016.11.1/parabuntu-2016.11.1-hdmi-z7020.img.gz
2. headless https://github.com/parallella/parabuntu/releases/download/parabuntu-2016.11.1/parabuntu-2016.11.1-headless-z7020.img.gz
aolofsson wrote:Sorry to hear that. Please specify EXACT path to binary downloaded and we will verify on our end as well.
korifey
Postby olajep » Mon Jan 09, 2017 3:26 pm
Hi korifey,
Sorry to hear that your board is not working.
What is the rating on your power supply?
Do you have a different power supply you can test with?
Does it work if you try this?
sudo rmmod epiphany || echo reboot the board and try again
sudo modprobe epiphany nopm
dmesg | tail -n20
Please reply with the output from the commands above.
// Ola
Postby korifey » Tue Jan 10, 2017 8:22 pm
Hello Ola,
thank you for your response.
At first i ran parallella with two different power supplies.
1. Portable 5V with 2.4A current output
2. Delta Elektronika SM 70-AR-24 (Output current max 24A)
Also always with heatsink and chip temperature was under 40°C = 104°F.
Make separate test with power cable from my BeagleBone board and microUSB.
Tried 3 latest images with 4 SD Card. (Wrote Images on Linux (Ubuntu 16.04), Windows 8.1, Mac OSX)
1. https://github.com/parallella/parabuntu/releases/download/parabuntu-2016.11.1/parabuntu-2016.11.1-headless-noelink-z7020.img.gz
2. https://github.com/parallella/parabuntu/releases/download/parabuntu-2016.11/parabuntu-2016.11-headless-z7020.img.gz
3. https://github.com/parallella/parabuntu/releases/download/pubuntu-15.04-esdk-2016.3.1/ubuntu-15.04-esdk-2016.3.1-headless-z7020.img.gz
Here is terminal output from commands
I run this many times.
1.
parallella@parallella:~$ sudo rmmod epiphany || echo reboot the board and try again
parallella@parallella:~$ sudo modprobe epiphany nopm
parallella@parallella:~$ dmesg | tail -n20
[   64.376163] ff40: 00038219 f0c93000 00038219 00000000 7f60d060 f0c93000 00038219 f0cbb294
[   64.383020] ff60: f0cbb0a7 f0cca55c 00003fb0 000046b0 00000000 00000000 00000000 00002200
[   64.389877] ff80: 00000031 00000032 0000001b 00000018 00000014 00000000 00000000 00000004
[   64.396733] ffa0: 00000000 c000ee00 00000000 00000004 00000003 7f60d1e8 00000000 7f615158
[   64.403590] ffc0: 00000000 00000004 00000000 0000017b 00040000 00000004 7f60d1e8 7f60d060
[   64.410465] ffe0: becc33b0 becc33a0 7f5f0683 b6e89622 80080030 00000003 03f728d3 3a58b27c
[   64.417359] [<bf00c950>] (elink_platform_probe [epiphany]) from [<c026a1cc>] (platform_drv_probe+0x50/0xa0)
[   64.425745] [<c026a1cc>] (platform_drv_probe) from [<c0268a2c>] (driver_probe_device+0x134/0x29c)
[   64.433284] [<c0268a2c>] (driver_probe_device) from [<c0268c14>] (__driver_attach+0x80/0xa4)
[   64.440399] [<c0268c14>] (__driver_attach) from [<c0267164>] (bus_for_each_dev+0x68/0x8c)
[   64.447256] [<c0267164>] (bus_for_each_dev) from [<c02680f4>] (bus_add_driver+0xc8/0x1e4)
[   64.454113] [<c02680f4>] (bus_add_driver) from [<c0269418>] (driver_register+0x9c/0xe0)
[   64.460822] [<c0269418>] (driver_register) from [<bf0100ec>] (epiphany_module_init+0xec/0x170 [epiphany])
[   64.469061] [<bf0100ec>] (epiphany_module_init [epiphany]) from [<c0009704>] (do_one_initcall+0x104/0x1b8)
[   64.477392] [<c0009704>] (do_one_initcall) from [<c00955d0>] (do_init_module+0x54/0x1ac)
[   64.484157] [<c00955d0>] (do_init_module) from [<c007d9d0>] (load_module+0x1748/0x1be4)
[   64.490829] [<c007d9d0>] (load_module) from [<c007e028>] (SyS_finit_module+0x88/0x90)
[   64.497354] [<c007e028>] (SyS_finit_module) from [<c000ee00>] (ret_fast_syscall+0x0/0x3c)
[   64.504193] Code: e5943180 e283380f e593320c f57ff04f (e3530000)
[   64.508967] ---[ end trace beb9350b2ab44e68 ]---
2.
[  248.380421] 7f40: 00038219 f0b53000 00038219 00000000 7f676060 f0b53000 00038219 f0b7b294
[  248.387277] 7f60: f0b7b0a7 f0b8a55c 00003fb0 000046b0 00000000 00000000 00000000 00002200
[  248.394134] 7f80: 00000031 00000032 0000001b 00000018 00000014 00000000 00000000 00000004
[  248.400991] 7fa0: 00000000 c000ee00 00000000 00000004 00000003 7f6761e8 00000000 7f67e158
[  248.407848] 7fc0: 00000000 00000004 00000000 0000017b 00040000 00000004 7f6761e8 7f676060
[  248.414704] 7fe0: beb623b0 beb623a0 7f659683 b6eaa622 80080030 00000003 00000000 00000000
[  248.421617] [<bf00c950>] (elink_platform_probe [epiphany]) from [<c026a1cc>] (platform_drv_probe+0x50/0xa0)
[  248.430003] [<c026a1cc>] (platform_drv_probe) from [<c0268a2c>] (driver_probe_device+0x134/0x29c)
[  248.437542] [<c0268a2c>] (driver_probe_device) from [<c0268c14>] (__driver_attach+0x80/0xa4)
[  248.444657] [<c0268c14>] (__driver_attach) from [<c0267164>] (bus_for_each_dev+0x68/0x8c)
[  248.451513] [<c0267164>] (bus_for_each_dev) from [<c02680f4>] (bus_add_driver+0xc8/0x1e4)
[  248.458370] [<c02680f4>] (bus_add_driver) from [<c0269418>] (driver_register+0x9c/0xe0)
[  248.465080] [<c0269418>] (driver_register) from [<bf0100ec>] (epiphany_module_init+0xec/0x170 [epiphany])
[  248.473319] [<bf0100ec>] (epiphany_module_init [epiphany]) from [<c0009704>] (do_one_initcall+0x104/0x1b8)
[  248.481632] [<c0009704>] (do_one_initcall) from [<c00955d0>] (do_init_module+0x54/0x1ac)
[  248.488415] [<c00955d0>] (do_init_module) from [<c007d9d0>] (load_module+0x1748/0x1be4)
[  248.495087] [<c007d9d0>] (load_module) from [<c007e028>] (SyS_finit_module+0x88/0x90)
[  248.501612] [<c007e028>] (SyS_finit_module) from [<c000ee00>] (ret_fast_syscall+0x0/0x3c)
[  248.508450] Code: e5943180 e283380f e593320c f57ff04f (e3530000)
[  248.513224] ---[ end trace e6aadb1cb0671fcc ]---
3.
[   94.589792] 1f40: 00038219 f0ceb000 00038219 00000000 7f5d3060 f0ceb000 00038219 f0d13294
[   94.596648] 1f60: f0d130a7 f0d2255c 00003fb0 000046b0 00000000 00000000 00000000 00002200
[   94.603505] 1f80: 00000031 00000032 0000001b 00000018 00000014 00000000 00000000 00000004
[   94.610362] 1fa0: 00000000 c000ee00 00000000 00000004 00000003 7f5d31e8 00000000 7f5db158
[   94.617219] 1fc0: 00000000 00000004 00000000 0000017b 00040000 00000004 7f5d31e8 7f5d3060
[   94.624094] 1fe0: beaca3b0 beaca3a0 7f5b6683 b6f59622 80080030 00000003 ebfffc0d e59d3004
[   94.630988] [<bf020950>] (elink_platform_probe [epiphany]) from [<c026a1cc>] (platform_drv_probe+0x50/0xa0)
[   94.639374] [<c026a1cc>] (platform_drv_probe) from [<c0268a2c>] (driver_probe_device+0x134/0x29c)
[   94.646913] [<c0268a2c>] (driver_probe_device) from [<c0268c14>] (__driver_attach+0x80/0xa4)
[   94.654028] [<c0268c14>] (__driver_attach) from [<c0267164>] (bus_for_each_dev+0x68/0x8c)
[   94.660885] [<c0267164>] (bus_for_each_dev) from [<c02680f4>] (bus_add_driver+0xc8/0x1e4)
[   94.667741] [<c02680f4>] (bus_add_driver) from [<c0269418>] (driver_register+0x9c/0xe0)
[   94.674451] [<c0269418>] (driver_register) from [<bf0240ec>] (epiphany_module_init+0xec/0x170 [epiphany])
[   94.682690] [<bf0240ec>] (epiphany_module_init [epiphany]) from [<c0009704>] (do_one_initcall+0x104/0x1b8)
[   94.691021] [<c0009704>] (do_one_initcall) from [<c00955d0>] (do_init_module+0x54/0x1ac)
[   94.697786] [<c00955d0>] (do_init_module) from [<c007d9d0>] (load_module+0x1748/0x1be4)
[   94.704458] [<c007d9d0>] (load_module) from [<c007e028>] (SyS_finit_module+0x88/0x90)
[   94.710983] [<c007e028>] (SyS_finit_module) from [<c000ee00>] (ret_fast_syscall+0x0/0x3c)
[   94.717821] Code: e5943180 e283380f e593320c f57ff04f (e3530000)
[   94.722595] ---[ end trace e1415d7097293ad6 ]---
I study electronics and work at Technical University of Berlin and would like to use parallella for measurement analysis.
Already spent a week in an attempt to start the Epiphany using a variety of combinations. (Images,SD cards and power supplies) without success.
Also i have good experience with RedPitaya (Zynq 7010), it was also a kikstater project, without any problems.
If you have any ideas that might help. Write to me, I'll be very happy.
Best wishes
Andrey
olajep wrote:Hi korifey,
dmesg | tail -n20
// Ola
korifey
Postby olajep » Tue Jan 10, 2017 10:02 pm
Andrey,
Sorry about that. It does look like you may have a defective board. Please return (RMA) it to the place of purchase so that we can have it looked at. We can then ship you a new board or offer a refund.
// Ola
