Parallella Community • View topic - First step with parallella
Re: First step with parallella
Postby zodane » Wed Feb 18, 2015 2:04 pm
zodane
Postby alga_kbk » Thu Apr 16, 2015 6:24 am
alga_kbk
Postby Nicolas-06 » Wed Nov 25, 2015 8:26 am
Nicolas-06
Postby sebraa » Thu Nov 26, 2015 10:21 am
You can access a simple memory-mapped device from Linux userspace through the use of /dev/mem. The Epiphany SDK used this interface before Adapteva did a Linux driver. However, I am not sure if you can actually use interrupts without at least a simple driver. Using /dev/mem is considered bad style, since your application then requires root access and is able to crash your Linux system easily, but it might suffice.
I don't know if Linux provides generic device drivers for simple devices. If that is the case (I think it is), then you just need to describe your IP (memory addresses, interrupt vector etc) in the device-tree and use that driver. But I don't have experience in those areas.
Postby Nicolas-06 » Thu Nov 26, 2015 2:56 pm
Thanks sebraa,
In fact, since there is no easy access to JTAG, it's """"simpler"""" to update the device tree and code a driver.
I too don't have much experience in writing drivers for Linux but fortunately I found a simple example here: http://forums.parallella.org/viewtopic.php?f=51&t=3297 :)
Nicolas-06
Postby peteasa » Thu Nov 26, 2015 9:00 pm
peteasa
Users browsing this forum: No registered users and 23 guests
