Vivado and Parallella
PostPosted: Fri Apr 03, 2015 1:50 pm
by Nader_Jendoubi
In the Xilinx documents, i found a document with the title is : Accelerating OpenCV Applications with Zynq-7000 All Programmable SoC using Vivado HLS Video Libraries and i download the project files from the link https://secure.xilinx.com/webreg/clickt ... cid=323570
i wanna ask if i can implement this project files in my parallella zynq and is it running good ???
Re: Vivado and Parallella
PostPosted: Fri Apr 03, 2015 3:23 pm
by boeserbaer
Your parallela has a zynq, so in theory it should work, the issues as to whether you can use the openCV acceleration would come down to:
1) Do you need the HDMI output from your parallella. If so, and you wan to use the latest ESDK, you will need to port the ADI HDMI project to Vivado.
2) Are there enough resources remaining in your Zynq? Do you have a 7010 or 7020? Did you use the HDMI?
Give it a try, and let us know!
Best Regards, Mike
