Recently, I've been told that I would work with 2 Parallella boards that my school ordered. I'm working at 50% there aside of my studies. One of the first things my chief told me was that I should search how it works, how to run a simple program and then how to use the two of them to split even more a task (let's say a dotproduct).
The first part was not that hard, even if I had sometimes to modify your Makefiles because it didn't work (if I remember correctly for xtemp the makefile doesn't work). But for the rest, there are lot's of examples, we have access to the SDK documentation, it's nice. I already tested the Parallella with a matmult against a CPU and a GPU.
But for the second part, it's really (really) not clear how we are supposed to use multiple cards. Maybe I'm blind but right now the only things I found searching around is that I can order the parts "BSH-030-01-F-D-A" from samtec and then know by myself how to go from there (build the cable, connect and run a program). The only way I see is using the ethernet port and do something via the network, but it's not nice because the board has the 4 samtec connectors.
Maybe you should add something to the samples, in the documentation, here on the forum but at least somewhere :
- you can do that
- you cannot do that (never or only not right now)
The best thing would be a tutorial with all the things needed and a sample program with 2 cards and a basic operation like dotproduct or matmult.
I'm asking that because one of the major advantages of this board is that you can buy one or two at the beginning, and then keep adding them to improve your computing power while managing easily your budget and 40 boards only draw 80W of power, which is the TDP of a standard Xeon CPU. 40 boards would be nice to benchmark against a 80W Xeon CPU .
Best regards
P.S. : If it already exists, I'm very sorry that I didn't find it
