Parallella Community • View topic - Nbody simulations on the Parallella
Re: Nbody simulations on the Parallella
Postby capnrob97 » Sat Jul 11, 2015 10:25 am
Trying to push my non MPI nbody code to github, get this error:
remote: Permission to parallella/parallella-examples.git denied to capnrob97
capnrob97
Postby tnt » Sat Jul 11, 2015 10:27 am
Well yeah, you can't push in that repo directly ... you have to do a fork of it under your account, push to that, then submit a pull request via the web ui.
Postby capnrob97 » Sat Jul 11, 2015 10:32 am
I am following Andreas's blog on using github.
I did the fork etc on my local machine, then when I try to do the git push it errors out.
Did the 'fork' then add, the commit.
The blog says to then do the git push followed by a pull request
capnrob97
Postby tnt » Sat Jul 11, 2015 10:47 am
you need to fork on github, under you account name, then clone to your local machine, then push to your fork.
Postby capnrob97 » Sat Jul 11, 2015 10:54 am
capnrob97
Postby capnrob97 » Sat Jul 11, 2015 12:07 pm
It must have worked, Andreas merged it into the parallella-examples
This was my first attempt at nBody.
I pushed that one first since it should easier for people to build and run, doesn't rely on building other libraries or anything.
I will clean up my MPI version, document some steps and push it later this weekend.
Forgot to add, you can't run it in X windows, do the ctrl-alt-f2 to login and run it from the command line there.
capnrob97
Postby capnrob97 » Sat Jul 11, 2015 8:12 pm
Sent a pull request for the MPI Nbody example
Also fixed a hard coded screen resolution issue in the mini-body example, should auto size to your screen res now
capnrob97
