So what will you be doing with your Parallella?
Postby capnrob97 » Fri Jul 03, 2015 3:52 pm
Built a 4 board cluster today
Trying to get MPI built, but some errors compiling, working on that
capnrob97
Postby jahorin » Mon Jul 06, 2015 5:57 pm
Just got an 8 board cluster up and had troubles with MPI but figured them out. Let me know if you need help!
jahorin
Postby capnrob97 » Tue Jul 07, 2015 9:04 am
I got MPI working ok now, thanks
capnrob97
Postby aolofsson » Tue Jul 07, 2015 1:14 pm
capnrob97,
Can you open a separate thread on your n-body stuff. Fascinating work. Saw some of your videos:-)
Postby capnrob97 » Tue Jul 07, 2015 3:46 pm
aolofsson wrote:capnrob97,
Will do, working now on adding graphics to the US Army MPI nbody code from the link you provided earlier in this thread.
capnrob97
Postby xilman » Fri Nov 11, 2016 6:51 pm
xilman wrote:Longer term it should fit into my interests in image processing, computational chemistry and computational number theory.
Today this arrived at my ECMNET server:
[2016-11-11 14:27:40 GMT] GW_4_505: prime factor returned by paul@leyland.vispa.com (par3_2)!  Factor=193947590303151513210178748272702655079708377  Method=ECM  B1=43000000  Sigma=3
It's the first non-trivial (meaning more than 30 digits) factor found by my 4-board cluster. The code runs entirely on the ARM cores.
For the uninitiated, ECM is the Elliptic Curve Method of integer factorization and GW_4_505 is shorthand for the 244-digit composite factor of 505 * 4^505 - 1. The remaining cofactor is still composite and has 199 digits. The factor was found on the second core of the third machine in the cluster, as indicated by "par3_2".
If anyone here would like to join in, the ECMNET server is publicly visible at 109.109.168.71:8094 and I'll be more than willing to help you get started.
Paul
xilman
Postby thickglass » Mon Nov 28, 2016 7:36 pm
I'm planning to do digital video processing
thickglass
Users browsing this forum: Bing [Bot] and 3 guests
