Parallella Community • View topic - How to check ethernet bandwidth of the Parallella
Postby aolofsson » Fri Aug 22, 2014 9:08 pm
Re: How to check ethernet bandwidth of the Parallella
Postby ajtravis » Fri Aug 22, 2014 11:39 pm
Postby xilman » Sat Aug 23, 2014 8:31 am
xilman
Postby tajuma » Sat Aug 23, 2014 3:09 pm
tajuma
Postby greytery » Sat Aug 23, 2014 5:07 pm
Postby aolofsson » Sun Aug 24, 2014 6:06 pm
tery, tony, xilman:
Thanks for the feedback! Three variables have changed: new defconfig, updated linux kernel, and using a newer linaro tree. I hope to have a new beta headless release version up this week for some brave souls to try.
Right now, it does look like the new configuration has possibly boosted ethernet performance from ~200Mb/s to 500Mb/s. I haven't found the root cause for this nice bump, so fingers cross that it's actually "true". :D
Postby Morgaine » Mon Aug 25, 2014 9:54 am
Alternatively use the venerable utility and you can compare your throughput against the nice little table of that we created at Element14 for the most common current ARM boards, plus a few others for comparison.
Details of running nuttcp are given in the linked thread, but in a nutshell it's simply to run "nuttcp -S" on some server "X" and then run "nuttcp -t X" and "nuttcp -r X" as transmit and receive tests to and from the server. Parallella can play the server or client role, whichever is more convenient. (iperf should of course give similar results, although comparing against our table is most fairly done using the same utility we used.)
The maximum theoretical TCP throughput over gigabit Ethernet is 941.482 Mbps with TCP TimeStamps enabled, or 949.285 Mbps without. All modern x86/amd64 equipment reaches that limiting throughput without any difficulty at all, but the gigabit-capable ARM boards we tested were nowhere near the theoretical maximum by quite some distance. Some boards couldn't even fully utilize a 100 Mbps link.
Hopefully this year will see newer ARM devices putting up a better showing. :-)
Morgaine.
Morgaine
Postby ajtravis » Mon Aug 25, 2014 10:45 pm
Postby greytery » Tue Aug 26, 2014 9:27 am
Postby tajuma » Tue Aug 26, 2014 12:16 pm
tajuma
Users browsing this forum: No registered users and 67 guests
