Parallella Community • View topic - Two questions on the parallella
Postby Lou_Reed » Mon Oct 06, 2014 2:32 pm
I almost have my paraellella set up. Everything is there as in the picturew shown in quickstart, shown here:
http://www.parallella.org/quick-start/
I have two questions, however, they are:
1. How do I know if I have a high def connection or not?
2. Can I conect a mouse and if so how do I connect a mouse.
Any help appreciated.
Thanks in advance.
Resepctfully,
Lou Reed
Note thta I have the board in the link that must use a fan.
Lou_Reed
Re: Two questions on the parallella
Postby 9600 » Mon Oct 06, 2014 4:09 pm
Postby Lou_Reed » Mon Oct 06, 2014 5:44 pm
Okay, to consider the second part first. The only connection that I have left is the USB connection on my parallella after connecting network, power and monitor. It is in the lower left hand corner of the picture shown on the link in the original question.
I assumed that was for the keyboard. There is only one connection and it would have to be for the keyboard!
You are saying to use it for both the mouse and keyboard via the USB hub. Connect mouse and keyboard to USB hub and connect the hub to the single USB.
Is that the way to do it?
Respectfully,
Lou_Reed
Lou_Reed
Postby 9600 » Tue Oct 07, 2014 7:28 am
Yes, it's a standard USB port and as such it can be used just about any USB peripheral in principle. So, if you want to connect a keyboard and mouse, you will need a USB hub — just as with any other computer that has only one USB port.
Postby Len » Sun Oct 19, 2014 4:15 pm
Although I am using a powered USB Hub so I can plug in USB sticks, my keyboard and mouse are a wireless pair from Logitech, the K330 which is fairly inexpensive. It worked right out of the box, plugged it in and I had a keyboard and mouse. It is the only keyboard and mouse I have ever had for the Parallella.
Len
Postby Lou_Reed » Wed Dec 17, 2014 6:11 pm
Okay, but do I need a powered USB hub of not?
Respectfully,
Lou_Reed
Lou_Reed
Postby xilman » Wed Dec 17, 2014 9:11 pm
xilman
