Parallella Community • View topic - Board only boots up successfully 1 out of 2 times
Postby Pieter-Jan » Wed Nov 12, 2014 7:04 pm
I'm running the headless ubuntu. My parallella is only booting up correctly (I can only find it on my network) 1 out of 2 times. Is this a known issue? Is there something I can do?
Pieter-Jan
Re: Board only boots up successfully 1 out of 2 times
Postby greytery » Wed Nov 12, 2014 9:50 pm
Hi PJ,
Could be one of a couple of things, esp. power supply to the board.
You should check out the .
The UART cable is a very, very useful tool!!
Cheers
Postby Pieter-Jan » Thu Nov 13, 2014 10:49 am
My power supply is 5V 2.2A so that should not be a problem.
The lights on the ethernet connector are always flickering green or orange so that's good too.
I have checked the files on the SD card a few times and don't see a problem here. Especially since the board is booting properly 50% of the time ...
I will see if I can do anything with the UART port but I have not used this interface before.
Pieter-Jan
Postby 9600 » Thu Nov 13, 2014 1:28 pm
Can you try this alternate devicetree configuration that Fred posted and let me know how you get on.
viewtopic.php?f=50&t=1622&p=10037#p10037
Postby Pieter-Jan » Thu Nov 13, 2014 6:58 pm
Hey guys,
The solution with the new devicetree worked! No idea what it did but everything works now. Board boots up every time ...
Would it be possible to make this the default devicetree for the headless version?
Pieter-Jan
Postby 9600 » Thu Nov 13, 2014 10:01 pm
Glad to hear this was resolved!
