Why enter password so often?
Postby Lou_Reed » Fri Jan 30, 2015 6:10 pm
After we have logged in as linaro at the beginning of a session why is it necessary
to re-enter our password once the again when running certain programs and why do we need to enter
ctrl-alt-F2 when we want to run other programs?
In my experience with Centos/Redhat you enter a password as a super user only to verify
that you are about to make a change in the Linux OS. But it seems that you do not have to do that here.
As I said in the paragraph above the only time is to run certain Parallella/epiphany programs.
As help appreciated.
Thanks in advance.
Respectfully,
Lou_Reed
Lou_Reed
Re: Why enter password so often?
Postby 9600 » Sat Jan 31, 2015 11:03 am
Lou_Reed wrote:As I said in the paragraph above the only time is to run certain Parallella/epiphany programs.
Because /dev/mem needs to be opened and you clearly don't want normal users to be able to do this! However, if you were to build a kernel and SDK from git you would get a new device, /dev/epiphany, and an SDK that uses this to load programs. Then you can set whatever permissions you like on that device.
