Parallella Community • View topic - dot product
dot product
Re: dot product
Postby aihaike » Tue Sep 16, 2014 10:21 pm
I thought this path was relative to where the binaries are located, but it seem to be relative to where you actually execute the code.
Thank you for pointing out.
aihaike
Re: dot product
Postby bayalievu » Wed Dec 03, 2014 7:02 am
bayalievu
Re: dot product
Postby 9600 » Wed Dec 03, 2014 12:25 pm
Re: dot product
Postby Urhixidur » Fri Feb 13, 2015 4:47 pm
Urhixidur
Re: dot product
Postby Urhixidur » Fri Feb 13, 2015 7:18 pm
Urhixidur
Re: dot product
Postby smatthews » Wed Jul 08, 2015 1:43 pm
I've updated the dot-product program that generalizes the example to sop of i = 0 .. N-1
This better illustrates how to achieve task-based parallelism on the Epiphany architecture. The new code is now accessible from the repo.
If you modify this example, please recognize that you will need to update RESULT in main.c to correspond with the N that you use in common.h. Currently N=64 and RESULT=85344.
The equation to use is
RESULT = ( N(N-1)(2N-1) )/6
I've run into troubles with N > 1024. Still looking for a way to fix this.
Best,
Suzanne
smatthews
Re: dot product
Postby MiguelTasende » Thu Jul 16, 2015 6:58 pm
Hi Suzanne,
I read your tutorial, and made my own modifications to the dotproduct code... (tried to do so before reading your answers :) ).
I fixed all the bugs almost the same way as you did, and finally could work with a=b=1:2048 (or 0:2047 whatever...), but couldn't solve the 4096 problem.
I still don't quite get it. I am working with "unsigned long" now, instead of "unsigned int". I see that some of the results go beyond what is manageable with 32 bits and I assume there is the problem...
But, I am working with "unsigned long" (host and device side), and Epiphany supports it, so I assume it correctly multiplies two unsigned long. Maybe my lack of C experience with large integers has something to do with it...
Well, the result is clearly less than 2^64, so if all long operations are working ok, I can't see where the problem is...
I'll try to see it later, now I will follow other paths in my "research", but will keep the problem in mind, and if anyone could generously help with a tip... I would be most grateful :)
MiguelTasende
Re: dot product
Postby MiguelTasende » Thu Aug 06, 2015 2:05 pm
Thinking about another problem now I may have an idea of where the problem may be.
It's not the capacity of the single "long", but the amount of them...
4 bytes (at least) per long
2048 longs
= 8192 = 8KB = the size of a memory bank
Above that it doesn't work correctly.
I think the problem is with memory management (should look at the linker script to see the memory allocation).
MiguelTasende
Re: dot product
Postby smatthews » Mon Aug 24, 2015 6:45 pm
Hi Miguel,
I think your last post gets to the heart of what I suspect to be the case as well.
The individual memory banks are 8KB. If we exceed the capacity of the memory banks, I believe the answer is to fetch from main memory. However, operations like this on the DMA channel is expensive. I think that one thing this example illustrates is that the Parallella exceeds at pure task parallelism. There are some limitations to data parallelism.
-Suzanne
smatthews
Re: dot product
Postby sebraa » Tue Aug 25, 2015 6:20 pm
Users browsing this forum: No registered users and 21 guests
