Parallella Community • View topic - OpenCV
OpenCV
OpenCV
Postby Nader_Jendoubi » Mon Mar 02, 2015 8:40 pm
Hi
I installed OpenCV library for a video application.
I write a program a run it. It works very well.
My question is : Can i use both of my ARM cores for running an OpenCV application.
If possible, how can i do it???
Excuse me if my question seems naïve but i'm really new on Parallella
Nader
Nader_Jendoubi
Re: OpenCV
Postby sebraa » Tue Mar 03, 2015 2:18 pm
This is not a Parallella-related question. :-)
Yes, you can use multiple CPUs in a Linux environment if you use multiple threads or multiple processes. Also, OpenCV has a parallel_for construct, which you should be able to use. From a pure software/Linux point of view, the ARM side of the Parallella does not differ significantly from any other Linux on a PC.
Re: OpenCV
Postby BOBNINO » Sat Mar 14, 2015 10:41 pm
i tried to install the opencv on my parallella and i get this error
libgtk2.0-dev : Depends: libpango1.0-dev (>= 1.20) but it is not going to be installed
Depends: libcairo2-dev (>= 1.6.4-6.1) but it is not going to be installed
any suggestions??
im using ubuntu 14.04 image.
when i try to install these dependencies i get more and more dependencies
any solutions.
BOBNINO
Re: OpenCV
Postby 9600 » Sun Mar 15, 2015 4:30 pm
Please see my reply to your post in another forum, and also if you could please refrain from posting the same question to multiple forums.
Users browsing this forum: No registered users and 42 guests
